Sponsored by: Auxito
Signal Mirrors
Old Oct 11, 2005 | 09:32 AM
92merc's Avatar
92merc
Signal Mirrors
OK, I thought I posted this yesterday, but the gremlins must have deleted the post.
I have a 2003 SCrew XLT with power mirrors. What I would like are the OEM power SIGNAL mirrors. I found one aftermarket that looks like OEM with the Chevron <> symbols behind the mirrors. But at $200, it's a little hard for me to justify. I was hoping someone might know of anyplace to pick up some Ford mirrors cheaper.
I also looked at some "stick on" LED from EBay for $20. But I'm concerned they'd look cheap. And I haven't seen any OEM signal power mirrors pop up there yet in the past few weeks either.
Any help is appreciated.
Old Oct 11, 2005 | 09:53 AM
MrBSS's Avatar
MrBSS
I went through just what you are. Yes, the stick-ons look cheap. I got a pair of OE style signal mirror glass on eBay, which initially seemed good. After one winter, the mirrors' silvering failed. I later learned that the manufacturer had a recall, and apparently, I had been sold one of the bad pairs. Fortunately, Muth Mirror ( the OE manufacturer) did replace mine. I was also able to upgrade to the heated mirrors.
Because of the possibility that more defective mirrors are out there, you should be very careful who you buy from. It's not real quick to put them in, so even if they guaranty replacement, it may not be good enough. Frankly, if you want them that badly, you should probably get them direct from Muth.
PS: People really notice the signal mirrors, which helps alot when you want to change lanes!
Old Oct 11, 2005 | 11:05 AM
BillyBob69's Avatar
BillyBob69
MrBss....Muth?
Old Oct 11, 2005 | 12:00 PM
Smaug's Avatar
Smaug
Muth is the manufacturer of the signal mirrors.
Old Oct 11, 2005 | 12:08 PM
92merc's Avatar
92merc
So Muth basically makes just a replacement piece of glass that goes into my stock housings if I'm understanding you correctly?
I'll check them out.
BTW, is the signal wire there already? Or will I need to run some new ones under the dash?
Old Oct 11, 2005 | 12:10 PM
92merc's Avatar
92merc
Thanks!
Old Oct 11, 2005 | 12:53 PM
BillyBob69's Avatar
BillyBob69
AHHHH!!!!! I'm seeing double!!!!!
Old Oct 13, 2005 | 09:00 AM
MrBSS's Avatar
MrBSS
The signal mirror has wires which plug into the existing mirror control harness in the door (at least it was existing on mine). The LED's draw very little current so don't require any further changes. But if you get heated mirrors, you may have to re-wire.
Muth sells a kit for converting. I believe it consists of the same basic parts as they supply to Ford for OEM, but they specifically do not sell the Ford parts directly.
Incidentally, I have an F150 Supercab. I believe your Supercrew has mirrors like the Expy which, although they look the same, are different internally. You should not assume that what works in a regular F150 will work in yours.`
fp_5
2004 - 2008 F150
Mar 2, 2015 04:42 PM
Waff78
2004 - 2008 F150
Feb 6, 2015 09:55 AM
EPI-911
Aug 26, 2014 12:44 PM
FarmingFord
Jan 12, 2009 05:20 PM
