Sponsored by: Auxito
headlight switch or multifunction swithc problem?
Old Oct 11, 2005 | 08:57 AM
fordmanss12's Avatar
fordmanss12
Hi guys, on my 1998 F150 my high beams stopped working. I could pull the switch back and flash to pass would work but no high beams when in the forward position. Well checking it out yesterday it seems low beams aren't working either it's just the DRLs that are on. So.... does this point more to the multifunction switch (which seems a bit loose in the column) or the headlight switch??? thanks
Old Oct 11, 2005 | 09:13 AM
ddrumman2004's Avatar
ddrumman2004
I would suspect the switch as I have replaced the multi-switch in my 97 Lariat already. My low-beams would go off while driving at night....a dangerous situation in my area....although the high-beams and turn signals worked. I bought a new switch for 50 bucks(approx.) and installed it in less than 45 mins., as well as I remember.
Old Oct 11, 2005 | 09:41 AM
fordmanss12
thx for the reply. Sorry do you mean you would suspect the multi-switch? You replaced your multi-switch and that did, or did not, fix the problem??
thanks
Old Oct 11, 2005 | 10:40 AM
PaulC's Avatar
PaulC
A bad multi-function switch will create the problem you describe. Just make sure that the new one is for an F-150 and not an Expedition, unless you plan to install a rear window wiper anytime soon
doublemfarm
19
Feb 11, 2021 03:05 PM
chardagha
Mar 20, 2015 07:17 PM
blaze1214
Dec 19, 2014 08:55 PM
jjdoyle
Jan 3, 2011 08:38 AM
al_huryn
1978 - 1996 Big Bronco
Mar 14, 2007 07:51 PM
