Squeaky seat/ passenger power window
Old Oct 10, 2005 | 10:52 PM
guthrie&co's Avatar
guthrie&co
2 problems here. I have a squeaky seat, it seems that when i make a turn the driver seat make a noise...might just need to be tightened up
Also i have a passanger side window that the motor seems to have quit working. i pulled the door panel off , and almost all of the plastic clips ended up on the floor. and found that if i pull the motor to me, just a slight bit of pressure , it works just fine. but when you let go of it it locks up tighter than fort knox. I tried putting a zip tie around the motor and that didnt work at all. Have any of you guys seem this problem before? do i just need to break down and get a new motor for the window?
By the way switches are ok.
Old Oct 11, 2005 | 07:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Try a little vaseline or other light grease in the window tracks.
Old Oct 12, 2005 | 07:50 AM
Calli's Avatar
Calli
Guthrie, Try spraying some WD-40 on and in the motor. I had the same problem and had some moisture present. I assume rain running down the glass into the door.Carroll
Brian429
2004 - 2008 F150
Dec 23, 2008 08:55 PM
tooldad
2004 - 2008 F150
Jul 18, 2008 10:48 AM
BroncoBuster
1978 - 1996 Big Bronco
Jun 18, 2005 11:18 PM
96 Danger Ranger
1983 - 2012 Ranger & B-Series
Jan 12, 2004 10:30 PM
hipster
1997 - 2003 F150
Jul 28, 2000 12:45 PM
