Spring eye pin removal on 48 rear (subtitle: how do you get the dang thing out)
Originally Posted by texan2004
I'll give it a look George but it looks to be too fine to be pipe thread.
Thanks - I'll let you know what I find out.
Now, here's another tip. If you replace the bushings too, use a socket about the same size as the bushing, and you can drive that out with a hammer too. Just use an old beat up socket, if you have one
53fat - I would be nice to be able to punch it straight out but the access hole in the frame to punch the pin out of the front pin on the rear springs is blocked on the 48-50's by the rear cross member braces. Big time 55 year old engineering oops by Ford but not fatal. Many folks simply cut a hole in the interfering plate/bracket and rolled on. I wanted to avioid that if at all posible. I trust they corrected this problem in later years.
George - It was 1/8" NPT - Thanks for the answer. Problem is I could not easily locate anything but brass in 1/8" NPT. Tried it with my mega slide hammer - about a 25# cylindercal weight that slides over an old car axle with a big a$$ nut welded to the end. Very effective. I'll have to post a picture sometime. Anyhow, all it did was snap the brass set-up I put together on the first pop with the slide hammer.
I ended up grinding off the rviets from the offending plate. It needed to be removed anyway because I had rust puckering up in the bottom seam between the plate and the frame.
Thanks and appreciate the help. I've not popped the bushings out yet. Where did you get your new ones? The manual doesn't go into much deatil on how to replace these or what they look like. Everything on mine is so crudded up, it's difficult to discern bushing form the spring eylets so I can't tell what the look like or how deep they go in. Which side did you drive the bushing from/to?
Thanks
Carl
Thanks
Carl
Thanks
Carl
Thanks
Carl
Good, luck. Any more questions, just ask
I got the pins and bushings from a local spring and suspension outfit. As I mentioned in my previous post, my x-member had holes torched into it but not inline with the pins. I had a length of 1/2 round stock that I used for a drift. Not one of my favorite jobs on these old trucks. I wish I would have had the bed off of the truck when I did it, it sure would have made things alot easier..
On one side there wasn't even a pin in place. The previous owner had just stuck a large bolt in the hole. the only thing that kept if from falling out was the bedside of the truck....nice huh?
Bobby
Bobby
eman92082
11-30-2020 08:21 AM
bconnel1965
03-27-2014 01:49 PM
Outlaw56
15
09-10-2013 03:12 PM
tomrflorida
10-03-2012 12:17 PM
trevor8283
04-23-2012 09:34 AM
