The Tow Boss package upgrades the GCVWR(Gross Combined Vehicle Weight Rating) to 26,000lbs. So 26,000 minus the weight of your truck, is what you can tow. That is putting it in simple terms, don't forget about the pin weight although I don't think that will be an issue.
I noticed with the airbags; that the airbag on the drivers side has a little lever above it. The lever must have something to do with using the airbags. The lever is engaged when there is weight on the truck bed (fifth wheel). How would this work.
Thanks.
Sounds like you have an automatic system installed. The lever senses the position relationship between axle and frame. When you put the weight of a trailer on the back end, the backend drops down, changing the position of the lever. The lever then opens an air valve and puts more air into the airbags. The process is reversed when you take the weight of the trailer off of the truck.
