Hedder Gaskets
Old Oct 9, 2005 | 08:41 AM
Fireman1212's Avatar
Fireman1212
Hedder Gaskets
Hey what are some good gaskets to pick up for hedders? And where do you get them?
Old Oct 9, 2005 | 06:21 PM
95 F150's Avatar
95 F150
I've had good luck with my Percy's dead soft aluminum header gaskets, they are reusable and wont burn out. I bought them 2 years ago at Autozone for about 40 bucks.
Old Oct 9, 2005 | 07:26 PM
ford5.8's Avatar
ford5.8
I like Percy's as well..
Old Oct 15, 2005 | 01:13 PM
F350 Strait's Avatar
F350 Strait
Re: Header Gaskets
I've read that you don't need a gasket if you use the high temp. silicone sealers (Orange or red). I am in the process of bldg an engine and plan on trying it.
Earl
Old Oct 15, 2005 | 01:46 PM
Fireman1212
As far as application goes would you put it on the inside of the hedder flange to take the place of a gasket or bolt it up and seal around the outside edges of the hedder?
Old Oct 15, 2005 | 05:57 PM
F350 Strait
I'd put a bead around the exhaust openings then bolt the header to the block. Similar to using the silicone to seal the front & back of the intake manifold.
chris69
Nov 20, 2003 06:36 PM
dustinleavitt2000
Jan 5, 2003 01:34 AM
Bogaski
Exhaust Systems
Dec 11, 2001 04:20 PM
xaviar
Apr 18, 2001 12:55 AM
bigsteve
Oct 8, 2000 01:20 AM
