Cowl Lace Installation
Old Oct 8, 2005 | 06:47 PM
davidgeno123's Avatar
davidgeno123
My '67 F100 had no cowl lace weatherstrip when I got it, just a row of holes in teh firewall below the rear shut line for the hood. I bought a new cowl lace kit from LMC. The spacing of the clips is a little off, but I can fix that. Should the cowl lace molding be installed with the angled lip facing up? or down? Also, should the molding be installed with adhesive as well as the clips that are attached to it? Thanks for any advice ad help. David G
Old Oct 9, 2005 | 10:41 AM
ceetwarrior's Avatar
ceetwarrior
David G, send that cowl lacing back to LMC. It is NOT correct for 1967's. I went throgh the exact same thing with my '67.
Get the correct one from Dennis Carpenter... it's about the same cost.
The one from LMC is for later models but they haven't figured out yet that it doesn't fit the 1967. The 67 has little plastic push snappers that fill the holes when you mount the rubber. Where the LMC has these crappy metal pins that the holes aren't even the correct spacing for.
But regaurdless, the rubber mounts with the flat part up then the mounting deals downward.
Old Oct 10, 2005 | 12:30 PM
qman's Avatar
qman
My neighbor bought one of them cowl lacing and it doesn't seal real good. I went and bought an $8 generic weatherstrip from Autozone and it seals much better. It's cross section was shaped like a circle sitting on top of an upside down T.
ceetwarrior
19
Apr 27, 2017 10:59 PM
edzakory
Mar 16, 2017 10:44 AM
sdetweil
60
Sep 4, 2016 01:43 PM
youngblood1989
Aug 25, 2016 11:18 AM
Longgone
Apr 18, 2016 05:09 PM
