c6 governor
Old Nov 29, 2021 | 02:10 PM
Everett stormy's Avatar
Everett stormy
ITS been Almost 20 years and i Need answers!
First of all i hope everyones old trucks are doing well, also Mines doing this! its been almost 20 years and still no one has answered this stupid question? seriously? mine is just starting to have problems shifting from 2nd to first and it acts a little inconsitantly sometimes. Can someone please link to instructions or help of some sort?
Old Nov 29, 2021 | 11:23 PM
Greaser007's Avatar
Greaser007
My trans builder said the governor slides off the front of the mainshaft requiring disassembly to change it.
I have the wrong one in my ford Van and it needs further delay before upshifting (like a trailer tow mode).
Old Nov 30, 2021 | 10:28 AM
tbear853's Avatar
tbear853
I did something to it in the '80s as installing a Mister Shifty kit from Napa, did not remove the transmission. I forget details.
Old Nov 30, 2021 | 01:57 PM
mark a.'s Avatar
mark a.
That sounds more like the shift modulator needs adjusted. Pull the vacuum line off and see if there is a small allen head screw down in it for adjustment. If there isn't then get one that is adjustable and go from there. Also they do make different length shift modulator rods.
Old Sep 7, 2022 | 08:01 PM
Dailydriver22's Avatar
Dailydriver22
Even though this is an old thread I have decided to try my luck. My 88 f250 2wd seems to not have a 3rd gear. It doesn’t even make an attempt to shift up, the only shift I get is at 22ish mph and 2200rpm, then what I believe to be second takes me up to 65 but I’m holding it right over 3k rpm. I replaced the vacuum modulator and there was no needle in the old one to swap out. I figured if the modular didn’t work then it would be time for a rebuild, but I was told to try the governor before resorting to a rebuild. Thoughts?
Old Sep 8, 2022 | 11:05 AM
5851a's Avatar
5851a
If there is no pin in the modulator it fell out during changing, at some point in time on an attempted repair. Doubt if it will ever shift to 3rd, surprised it makes a shift to 2nd unless manually selected.
Old Sep 8, 2022 | 11:10 AM
Dailydriver22
Before I changed the modulator if I wanted to upshift I would just have to let off the throttle around 20mph and 2200rpm. After changing it the truck will shift without me letting off but it’s a super slow shift unless I do let off. As for 3rd gear, will I never see it unless I opt for a rebuild?
Old Nov 1, 2022 | 08:09 AM
Pwizzle's Avatar
Pwizzle
1st Gear
C6
I have a C6 in my 71 f250. Having similar problems at others posting here. The trans is newly rebuild with about 50 miles on it now. Shifts smoothly, but unless I let off the accelerator momentarily, it will not up shift into second and never seem to shift into 3rd. Any ideas? It has a new modulator, pin, and good vacuum.
Old Nov 3, 2022 | 10:01 AM
tbear853's Avatar
tbear853
Should have been one. The C-6 modulator can't work without the pin.
C6 Modulator valve pin - Ford Truck Enthusiasts Forums (ford-trucks.com)
7379ford
Dec 5, 2016 09:12 PM
oldiron
Feb 13, 2010 10:41 PM
smallblock351w
Mar 24, 2006 02:55 PM
MKPJ1
Jul 1, 2002 08:07 PM
BB
Jun 12, 2002 06:56 PM
