General Diesel Discussion
Cummins/Ford
Old Dec 4, 2005 | 06:25 PM
  #31
dkstuck's Avatar
dkstuck
Okay, did you ever hear that before the international diesel Ford went to Cat and said, we want you to build us a diesel for our pickups, heres the specs. Cat said these are the engines we have and will not spec out a engine for you! Ford and Cat could not work it out so they went with International. Ford dealer told me that years ago.
Guess we need myth-busters, lots of fun though! Old hens around the sewing cicle! He HE
Old Dec 4, 2005 | 07:21 PM
  #32
handyman43358's Avatar
handyman43358
Go to the cummins website and look at their frequently asked questions. It says Ford has nothing at all to do with cummins. Ford does not own cummins, or any shares for that matter. So stop continuing the rumors lol. And the next person I hear telling me that theres a twin turbo cat going into the SD, I'm going to flat lay them out without asking any questions. Period.
Old Dec 5, 2005 | 02:45 AM
  #33
NickFordMan's Avatar
NickFordMan
Internet lay out...could be interesting...lol
Old Dec 5, 2005 | 05:16 PM
  #34
handyman43358
Lol I meant in person, but I'd find a way to lay em out on here too!
Old Dec 5, 2005 | 07:21 PM
  #35
NickFordMan
haha, yeah, I was just making a shallow observation. I knew what you meant.
Old Dec 6, 2005 | 05:08 PM
  #36
handyman43358
Lol I know buddy. It cracked me up when you said that.
Old Dec 6, 2005 | 07:30 PM
  #37
NickFordMan
haha, I understand your frustration. There's some kid on here trying to tell me that 7.3L diesel engines, and even 6.0L's for that matter have no low end. It's comical. He says Cummins are the be-all and end-all.
Old Dec 7, 2005 | 09:02 AM
  #38
handyman43358
Lol yea I think i was in the conversation. Hes wrong as far as the strokers not having any low end, because they do. But I do believe that cummins has more of it. Only thing is, the narrow powerband runs out quickly, unlike the stroker, which keeps an even amount of power.
Old Dec 7, 2005 | 10:17 AM
  #39
Customz's Avatar
Customz
Power is and always has been the area under the curve, not including drivetrain losses, aerodynamics, etc.
Old Dec 7, 2005 | 11:26 AM
  #40
Frost13's Avatar
Frost13
the cummins may have more low end than the psd and a little bit lower down, but the psd holds its power longer and better. we've started out on about a 10% grade in a standard psd with about 13k pounds of logs on it in 2 hi before.
Old Dec 7, 2005 | 05:36 PM
  #41
444dieselrod's Avatar
444dieselrod
heres another to add to the list.
Take a look at 3112 cat motor, tell me it doesnt look ALOT like a PSD.
IH and cat actualy worked on the HEUI set-up together. so Cat does have a motor that is very similar, it ust got built 12 years to late.
Diesel Rod
Old Dec 9, 2005 | 12:22 PM
  #42
16diesel's Avatar
16diesel
the 3112 cat it strickly commercial. they are also very particular about settings excetra. fore instance we had one in at a shop the injestion timing was off by a hair (enough to be noticed in a diesel but still run ok) and this thing could barley idel. we re adjusted the injectores and away she went like it was brand new. yes the 3112 looks alot like the psd and are both rated in the same area psd 235 hp, 3112 at 225hp
Old Dec 9, 2005 | 04:40 PM
  #43
handyman43358
Isnt the psd rated at 325? and 570 Lb-ft of torque? Tell me if im wrong there.
Old Dec 9, 2005 | 05:23 PM
  #44
NickFordMan
In their medium duty applications, the 6.0L, or 365VT is rated around 235 hp, and 670? ft/lbs of torque. Ford changed the software to make more hp. That's where a lot of the problems associated with the 6.0L are derived from.
Old Dec 9, 2005 | 05:42 PM
  #45
handyman43358
OHH I thought you were talking about the PSD before Ford tweeks with it. I gotcha!
