Pinging @ startup
Old Oct 11, 2005 | 11:41 AM
Blurry94's Avatar
Blurry94
Originally Posted by EPNCSU2006
I am not disputing that it runs richer in open loop as it is a failsafe. However, I don't consider high 12's (~.85LA) dumping a boatload of fuel.
Please excuse the term then. My point is that it is richer, and for it to knock/ping when it's rich, but not after it warms up and gets leaner, just doesn't make sense...see where I'm coming from?
Old Oct 11, 2005 | 11:49 AM
quicklook2's Avatar
quicklook2
okay, how is this for a clear post:
i use motorcraft filters.
i have never had a problem using motorcraft filters on ford vehicles.
I did have problems with fram filters in the past on a ranchero gt., problems went away when i used motorcraft.
When i bought this f150 it had a purolatar filter on it.
it had a clogged oil screen that had to be replaced.
after i put that in i used motorcraft oil filter because of my good experiences in the past with them.
the purolatar oil filter may or may not have been part of the problem, i do not know.
i am aware that motorcraft oil filters are made my purolatar.
all i am suggesting is that if in any way the oil filter has anything to do with his problem, than replace it with a motorcraft oil filter.
Old Oct 11, 2005 | 11:51 AM
Blurry94's Avatar
Blurry94
Originally Posted by subford
I have heard that Purolator makes the Motorcraft Filters for FORD.
Yes they are.
Old Oct 11, 2005 | 03:03 PM
royale5's Avatar
royale5
Originally Posted by MemOrex
When the engine is fired up cold, the ECT and i think ACT determine the timing. I would maybe check those sensors...particularly the ECT,
What and where is the ECT sensor??
Old Oct 11, 2005 | 03:42 PM
EPNCSU2006's Avatar
EPNCSU2006
Did you ever check for codes in the computer?
Sorry for being a pest, Blurry, I see where you were leading with your comments.
160buck
Jan 15, 2016 10:07 AM
SoCalAngler
Nov 25, 2014 05:38 PM
boyer669
Modular V10 (6.8l)
Aug 25, 2014 07:39 AM
njtinman2
23
Mar 26, 2014 04:39 AM
Jarryd
Feb 18, 2014 07:53 AM
