Pinging @ startup
Old Oct 7, 2005 | 02:27 PM
royale5's Avatar
royale5
Pinging @ startup
I reascently noticed my 95' 302 has developed a random pinging after startup. It is intermitant until the motor is warm. 118k miles on the clock. Anything I can do to fix that??
Old Oct 7, 2005 | 02:49 PM
dale gribble's Avatar
dale gribble
Sounds like it has too much advance before the computer goes into open loop mode after it warms up. After warming up the computer takes over and retards the advance so it doesn't ping anymore.
First things first, I would check the base timing. Do that, and see if it fixes it. Get the easy stuff out of the way first.
Old Oct 7, 2005 | 04:08 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer always has control over the advance - it's what advances the timing at all. It's still a good idea to check the base timing. I would also check for diagnostic codes in the computer to see if it is trying to tell you anything. Here are some instructions if you've never done it before: http://www.thorssell.net/hbook/eectest.html .
Old Oct 7, 2005 | 07:34 PM
Blurry94's Avatar
Blurry94
Wait a sec...is this at idle or drive. I find it hard to believe that it is an ignition problem being that the PCM dumps a boat load of fuel when in open loop. Are you sure it's a "pinging" type detonation noise or possibly a knocking noise. Sometimes you hear when the motor is cold, possibly an angry lifter.
Old Oct 7, 2005 | 07:36 PM
EPNCSU2006's Avatar
EPNCSU2006
^ I agree that the noise could be a lifter or other type of tick, but the computer doesn't just dump extra fuel in open loop. It just runs with no O2 sensor feedback, so it will err on the rich side of things to be safe, but doesn't just dump a boatload of fuel for no reason.
Old Oct 7, 2005 | 08:07 PM
Blurry94's Avatar
Blurry94
I have some datalogged files that show me it is richer in open loop, as per wideband and EASE scanner/datalogger. A/F ratios were high 12's in open loop, that's rich.
Old Oct 7, 2005 | 08:22 PM
EPNCSU2006's Avatar
EPNCSU2006
I am not disputing that it runs richer in open loop as it is a failsafe. However, I don't consider high 12's (~.85LA) dumping a boatload of fuel.
Old Oct 7, 2005 | 09:07 PM
rrzielin's Avatar
rrzielin
Question
What kind of oil filter are you running?
Old Oct 10, 2005 | 02:51 PM
royale5's Avatar
royale5
I have a purolator oil filter in it now. The noise is not constant it is random and happens about 12 or so times before the motor gets warm. This is at idle and if driving, but I notice it more at idle.
Old Oct 10, 2005 | 03:18 PM
quicklook2's Avatar
quicklook2
Originally Posted by royale5
I have a purolator oil filter in it now. .
use motorcraft oil filters.
Old Oct 10, 2005 | 10:28 PM
EPNCSU2006's Avatar
EPNCSU2006
There's nothing wrong with Purolators. In fact, they are one of the better filters available. There isn't anything wrong with Motorcrafts either, but I don't think it'll make any difference in this case. Since it is a switch, it turns on/off at around 7 psi. So even if the gauge is reading zero, there could be a little pressure there. It's not good, but it's better than nothing.
Old Oct 11, 2005 | 09:00 AM
quicklook2's Avatar
quicklook2
did not say anything wrong with purolator, i have had good luck using motorcraft filters on ford products.
Old Oct 11, 2005 | 09:33 AM
EPNCSU2006's Avatar
EPNCSU2006
You sure implied that something was wrong with it by telling the guy to use motorcrafts like it would solve his problem.
Old Oct 11, 2005 | 10:12 AM
subford's Avatar
subford
I have heard that Purolator makes the Motorcraft Filters for FORD.
Old Oct 11, 2005 | 10:49 AM
MemOrex's Avatar
MemOrex
When the engine is fired up cold, the ECT and i think ACT determine the timing. I would maybe check those sensors...particularly the ECT,
