94 5.0 pinging
Old Mar 20, 2014 | 08:44 PM
njtinman2's Avatar
njtinman2
94 5.0 pinging
i have a 94 f150 4x4 5.0 and it is starting to ping alot and feels like its losing power its been tuned up any ideas?
Old Mar 20, 2014 | 09:13 PM
carguy94's Avatar
carguy94
have your tried getting the codes if their is any what was done during tune up did the problem happen before or after tune up and just because what kind of fuel do you run
Old Mar 20, 2014 | 09:18 PM
danr1's Avatar
danr1
This start after the tune up or the tune up was done in attempt correct the problem? If started after the tune up I'd take a good look at the parts that where used.
Regardless have you checked/set the base timing?
Old Mar 20, 2014 | 10:19 PM
njtinman2's Avatar
njtinman2
long after the tune up, its been doing it more and more and now it is losing power going up hills. been running regular fuel but maybe i need higher grade fuel
Old Mar 20, 2014 | 10:30 PM
carguy94's Avatar
carguy94
well i wont say you need higher octane fuel but it could help the issue until you get it resolved pinging is usually pre ignition and what about trouble codes it could be alot of thing could be your truck is running lean and getting real hot or timing and so on but i would look for codes first if you can if it were me i would want a look at the plugs but not always the case no need to start their
Old Mar 21, 2014 | 08:59 AM
Conanski's Avatar
Conanski
Have a look at the motor in complete darkness and rev it to see if there is any arcing between plug wires or wires to block.
Pull codes and check fuel pressure.
Fix any leaks in the exhaust or air injection system upstream of the O2 sensor.
Old Mar 21, 2014 | 09:03 AM
White Max's Avatar
White Max
If your truck has a MAF, it would be worthwhile to clean it, especially if you're running an oiled air filter (like a K&N). Also, verify that you don't have any vacuum leaks.
Old Mar 21, 2014 | 11:09 AM
njtinman2's Avatar
njtinman2
already cleaned the maf sensor
Old Mar 21, 2014 | 08:21 PM
carguy94's Avatar
carguy94
pulling the codes not an option right now its any ones guess usually unless it was an extreme case a dirty mas air flow would not cause pre detonation unless your truck is running real lean and real hot how about idiot lights are you sure your truck is actually pinging does the pinging happen all the time
Old Mar 21, 2014 | 09:26 PM
Toplait's Avatar
Toplait
Can you video tape the truck running so we can hear the pinging sound by any chance?
Old Mar 23, 2014 | 09:30 AM
njtinman2's Avatar
njtinman2
the pinging is happining going up steep hills at about 3000 rpm and loses power. last night i was on the highway and had to slow down so it would stop. and the temp gauge was going up and down but never real high
Old Mar 23, 2014 | 06:38 PM
njtinman2's Avatar
njtinman2
ok i found a hole in the lower throttle body hose. and codes are 334 and 452 i have did not drive it yet since fixing the hose
Old Mar 23, 2014 | 07:41 PM
carguy94's Avatar
carguy94
did you clear the codes if this does not fix your problem pull the codes and see if anything changed
Old Mar 24, 2014 | 06:57 AM
njtinman2's Avatar
njtinman2
went to work today up a big hill and no ping and drove much better. now the brake question? when I go to stop I get a shaking of the truck like with out of round drums. but I put all new rotors and drums on it. can the abs valve on the frame cause this?
Old Mar 24, 2014 | 02:35 PM
carguy94's Avatar
carguy94
is the pulsating in the pedal or else were steering wheel rear end
