Transfer cases: NV271/NV273
Availability: NV271 - Standard 4WD ST
NV273 - Standard 4WD SLT Plus
Type: Part Time
Operating Modes: 2WD; 4WD High, Locked; Neutral;
4WD Low, Locked
Shift Mechanism: NV271 - manual, NV273 - electric
Low-Range Ratio: 2.72
Center Differential: None
Guess my 205 is ugly too sighs does that mean i'm gonna have to pull it clean it up and chrome it To make it look pretty? Ivan Ford uses both of those Tcases in there SD they are chain driven but are good for like 17,000 lbs of torque.
yea, the super duty t-case is rated for more torque than the 205, but it is much more vulnerable because if you hit it on the ground or a rock the aluminum case will crack. PLus you cant twinstick it.
i wish they would hurry up with a lomax 3:1 kit for a ford 205....and have much larger gears like they did for the chevy version
Clock it and run it above a flat belly, no worries from rocks then
I havent beat on a SD T-case, but i beat on BW in my 96F-250 like there was no tomorrow. Dyno proven 620 FT/lbs.... i would assume the SD t-case can take the same beating.
