fuel questions
Old Oct 5, 2005 | 12:57 PM
northernlights's Avatar
northernlights
fuel questions
Hello , problem is my fuel gauge. I bought this truck a month ago and thought the front tank was empty, the gauge read that way so I tried to fill it but it seems full.my sending unit must be bad.What I need to know is how much does the front tank on a 92 f-250 hold, I don't want to run the truck dry but need to empty it check it out. Thanks Craig
Old Oct 5, 2005 | 02:35 PM
lgspitler's Avatar
lgspitler
I also have a '92 F250. I believe the front tank holds 19 gal. I'll check my owners manual tonight and if it's different I'll let you know.
Old Oct 5, 2005 | 03:48 PM
PLC7.3's Avatar
PLC7.3
Could be the sending unit or the FSV (fuel selector valve).....if you want the FSV test email me.......subject FSV test.
Old Oct 8, 2005 | 04:51 AM
romcjr's Avatar
romcjr
I had the same problem.I removed the sending unit and cleaned the contact point with a pencil eraser.Works like a new one.I also had to change the FSV.
Old Oct 8, 2005 | 10:21 AM
northernlights
tank
Thanks for the feedback,I switched to the front tank so I can empty it.I will try cleaning the contacts and check the valve. I also cleaned my k&n filter and hardly any smoke now,I get a little puff of black smoke before the turbo spools up when I get on it I guess that probably normal. Thanks Craig
Old Oct 8, 2005 | 10:28 AM
nathan's greaser's Avatar
nathan's greaser
definitly check the contacts on the sendingunit. I had the same problem on my 85 f250, and cleaning the contacts worked. My midship tank holds 20 gal.
kermmydog
Jul 16, 2013 10:38 PM
90'F150
Jun 12, 2013 09:16 PM
DynaMow
Apr 2, 2009 11:12 PM
Gene Marsh
Jul 29, 2003 09:35 PM
