7.3 Tach (Problem???)
Old Oct 4, 2005 | 01:58 AM
LongArmSuperDuty's Avatar
LongArmSuperDuty
Hello,
I have a 90 F-450 Superduty 7.3, just noticed that when im in idle the tach is at zero. when i rev it or drive it moves normally......is this normal for these or is there a potential problem??
any suggestions?
Thanks,
Mike
Old Oct 4, 2005 | 12:25 PM
PLC7.3's Avatar
PLC7.3
The tach should work from start to finish with no down time.........check where the wires exit the sender quite often they are bare and short out until fan wind velocity move them. Check the connector too.
The dead tach should send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Old Oct 4, 2005 | 01:20 PM
goodie350's Avatar
goodie350
My tach does the exact same thing. As soon as the motor is reved it's reads fine. I haven't done anything with it since I have a 5 speed tranny and hasn't affected how it runs. Is it going to damage something if left alone?
Clint
Old Oct 4, 2005 | 11:14 PM
PLC7.3's Avatar
PLC7.3
Nope.......Just a pretty nifty guage on a standard, no effect on the trans ops other than you know when to shift it..........
Old Oct 5, 2005 | 12:21 AM
tdford's Avatar
tdford
I don't understand how the tack on these diesels works. If the tack is reading 0 at 600 rpm can it be trusted to read correct when it comes on at higher rpm or could it just be reading 600 rpm low?
Old Oct 5, 2005 | 06:12 AM
jboard's Avatar
jboard
Well i had the same problem and it turned out to be my idle was too low. Try to adjust your idle up a little until you get it around 675rpm according to the gauge. Mine works just fine.
Jeremy
Old Oct 5, 2005 | 09:20 AM
goodie350's Avatar
goodie350
I'm glad it isn't hurting anything. I actually think the problem with mine is a bad ground I haven't been able to locate. The tach will jump with the turn signals when they are on. When the truck gets warm most times it comes off of zero and is around 300 to 400 and doesn't jump as bad when the turn lights are flashing.
Old Oct 5, 2005 | 02:32 PM
lgspitler's Avatar
lgspitler
I'll second the bad sending unit idea. I had the same problem on my '92 and the sending unit fixed it. If you have the E4OD trans definitely change it. It's not going to get better and will "confuse" the trans as PLC7.3 said.
u.f.o
19
May 15, 2009 10:13 PM
gasgrunt88
Feb 3, 2008 10:28 AM
dieselbogging
Sep 15, 2006 05:32 PM
jqp00002
Apr 6, 2005 12:01 AM
woodyropes
Jul 14, 2001 01:35 PM
