Fmx To C6 Tranny Swap Need Help.
GETTING READY TO SWAP OUT MY TRASHED FMX CRUISOMATIC FOR A C6 IN MY 69 F100. wHAT PROBLEMS WILL I ENCOUNTER? AS FAR AS I CAN FIGURE THEY DIDN'T OFFER A C6 WITH THE 360 WHICH I HAVE THAT YEAR BUT THEY DID OFFER IT WITH A 390 AROUND THAT YEAR. WILL THERE BE PROBLEMS WITH THE OUTPUT SHAFT SIZE AND THE ADDITIONAL LENGTH OF THE C6? THANKS FOR THE HELP.
Have not done this in a truck, but I did in my Galexie. what I did find with the car was that the tail shaft was longer than the fmx, I had to cut a drive shaft to fit. The out put shaft was the same, the crossmenber/trans mount was differant. And the shifter was differant, C-6 went P-R-N-3-2-1, the fmx went P-R-D2-D1-L. If yu can get the trans mountfrom the donor truck. But if you getting the trans from a truck, you may not run into these things.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
parkerusmc Welcome to FTE The best truck show on the net
1- Be sure to get a C6 from a pickup rather than a car, because the shifting arm is at a different angle. You can find them until 77. The last year the FE was offered in 76. All FEs are the same on that end of the engine, so hooking up the tranny isn't a problem. C6s all are one piece cases, with different bells. You will have to have a round top FE C6 case tranny. You may need to swap the column also, because the whole shifting operation is different.
2- Chevy_Eater your tranny has been swapped out, there were no C4s installed behind FEs. That would have been for the FMX family tranny with the C4 designation.
3- I went with a one piece driveshaft when I converted my pickup. That is an option.
John
John
So it sounds like I am going to need a two piece drive shaft from the 67-72 and a steering column from a c6 donor truck. anything else? what about the tranny bracket will it bolt up or need to be moved? THANKS for the help everyone!
John
The truck FMX is not the same as a car one. The truck is a MX-HD medium case Cruiso-o-matic. It is of the FMX family but not a standard FMX. The shift pattering is the P-R-N-D-2-1.
