01 Navigator blowing fuses
Old Sep 29, 2005 | 02:51 PM
AYORK3177's Avatar
AYORK3177
Hey guys and gals. I originally posted this in the navigator area, but didnt find much help. Found this area and hoped that I could find some.
I have an 01 Lincoln Navigator with the alpine stereo system. My fiance was driving my truck when the stereo went dead. She could not offer any description other than it just quit working and that she didnt have it turned up very loud.
I remember that every once in a great while I would hear a clicking sound and a momentery cut to the stereo power when I put the drivers side window down.
I tried to replace fuse number 1 for the stereo that was blown, but it blew the second I put it in. I also replaced the stereo relay. Both of these were in the fuse box under the dash on the drivers side.
I removed the fuse box and gem module. The gem looked like brand new and was dry. From the outside, the fuse panel appeared to be in fine shape. Was afraid of breaking it, so I did not take it apart to look inside. When I buttoned everything up I left the stereo totally unhooked and removed. Still blew the fuse the second it was put in.
The truck does not appear to have ever had any aftermarket stereo equip. The previous owner had a phone kit in, as evident by the mic on the a pillar. Traced the wire and it was not hooked to anything.
I have no wiring diagram for this truck and have no idea where to look for my problems. I have hooked up stereo systems in the past, but never had to trouble shoot a factory one. Its much easier trouble shooting aftermarket as the wires are obvious. With stock, I have no idea what is what. I really appreciate any help anybody can offer. Goin nuts without my radio.
Adam
Old Sep 29, 2005 | 03:57 PM
AYORK3177's Avatar
AYORK3177
Oh, and I just remembered. On cold days shortly after starting the truck my oil pressure gauge and temp gauge would drop to zero at various times. I dont think they actually dropped to zero, but that there was somehting wrong with the gauges. Dont know if any of these items are linked together some how.
Old Jun 23, 2006 | 07:52 AM
mpelchen's Avatar
mpelchen
Lincoln Navigator blown fuses
I have the exact same stereo problem.It is the factory alpine system.I removed the head unit and replaced the # 1 audio fuse and POW. What have you found out or done?
Old Jun 23, 2006 | 07:54 AM
mpelchen's Avatar
mpelchen
Adam
I am ready to tear this whole beast apart The fuses blow instantly in audio #1 .I hope you can help me.
Thanking you in advance,
Mark
Old Jun 23, 2006 | 10:23 AM
projectSHO89's Avatar
projectSHO89
Fuse F1 supplies via splice S2012 (Ckt # 797):
Radio head unit
Subwoofer Amp
Navigation system display and module (if installed)
CJB fuse F31 (10A)
I'd disconnect the sub amp and the nav system components and see if the short circuit goes away.
Steve
Old Jun 23, 2006 | 11:56 AM
mpelchen's Avatar
mpelchen
I dont have the nav. Where do I find the amp?
Old Jun 23, 2006 | 01:57 PM
Franklin2's Avatar
Franklin2
Behind right side panel rear of vehicle
Old Jul 10, 2006 | 08:16 AM
mpelchen's Avatar
mpelchen
navigator short
I disconnected the rear subwoffer from the amp and replaced the fuse and it did not blow. Still no power . What next? THANKS
Old Jul 10, 2006 | 08:30 AM
projectSHO89
You probably have a shorted amp. Probably the final amp transistors since the current draw went away when you disconnected the speaker. Might be a shorted speaker coil. Check its resistance.
Steve
norman2012
Jul 24, 2016 11:12 AM
70FE250
May 2, 2016 10:17 PM
AnthonyC17
Nov 13, 2015 10:58 PM
bradphx
20
Jul 29, 2015 09:05 AM
emenko0809
Jul 7, 2015 06:43 AM
