Stereo problems.
Old Jul 13, 2015 | 05:03 PM
bradphx's Avatar
bradphx
Stereo problems.
So. Hooked up aftermarket stereo into the truck. Followed how the prev. Owner hooked up a different stereo which was am/fm with a tuning dial instead of digital. So I first hooked up the constant and accessory wires to the same wire. Then the stereo wouldn't stop reverting to demo mode. So I hooked up the constant wire to the cig lighter and now it's been draining my battery. Any ideas?
Old Jul 13, 2015 | 05:21 PM
GM4WALLS's Avatar
GM4WALLS
Red= switched 12V
Yellow= constant 12V
Black= ground
Blue= remote/power antenna
Sounds to me like you have your switched 12v on a constant feed wire.
Old Jul 13, 2015 | 05:32 PM
bradphx's Avatar
bradphx
I don't think so cause it shuts off when the key is removed
Old Jul 13, 2015 | 05:36 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The OEM radio was powered by a GREEN 2-terminal pigtail. YELLOW with a BLACK stripe is switched power, BLUE with RED stripe is dash illumination. Do not mistake the BLUE with RED stripe wire for ground. The OEM radio grounded through its mounting chassis. The speakers were connected over a separate pigtail.
Ok I looked behind the glove box and found a connection the goes off the green and yellow. GREEN with YELLOW stripe wiring is hot-at-all-times power for the courtesy lamp circuit, use that.
There is a 3-connector pigtail behind the glove box (which also goes on to power the cigarette lighter).
It's not the stock radio wire because the stock radio didn't need hot-at-all-times power (EXCEPT the factory digital AM radio for clock memory).
solid black—power
blue with red stripe--dial light
black with gray dashes—ground
orange with green dashes--right speaker
white with green dashes--left speaker
assuming an AM/FM stereo and stock wiring harness.
purple is ground, right speaker is white and left speaker is orange.
Old Jul 13, 2015 | 05:50 PM
GM4WALLS's Avatar
GM4WALLS
Have you had your battery checked? How long does it take to kill your battery?
Do the stereos presets stay saved when you turn the key off?
Old Jul 15, 2015 | 08:05 AM
bradphx's Avatar
bradphx
Sorry. Was abducted by aliens. Jk. Was working. All the presets stay but the battery still drains. The battery is like 3 weeks old. Just bought it out of Walmart but it looks considerably smaller than the one that was in it when I purchased the truck but the Walmart guide says it's the right one and so does check(refuse to call it the new name)
Old Jul 15, 2015 | 12:31 PM
84espy's Avatar
84espy
The drain from your radio should be a minor thing. It may be a result of another electrical issue. You say you replaced the battery 3 weeks ago. Have you checked out your alternator/regulator also?
Old Jul 15, 2015 | 01:06 PM
bradphx's Avatar
bradphx
I jumped it Monday and ran it for a bit and as of today it's still good. I think the alt is good. I'll wait till Saturday when I have time to dig into the stereo.
Old Jul 15, 2015 | 06:33 PM
GM4WALLS's Avatar
GM4WALLS
That said, I highly doubt it's the stereo. Why did you replace the battery three weeks ago?
Old Jul 18, 2015 | 12:57 PM
bradphx's Avatar
bradphx
Ok so the aftermarket stereo that was in the truck when I bought it had the red and yellow wires hooked up to this blue wire that's connected to the yellow w/black stripe and a light blue wire. What are these???
Old Jul 18, 2015 | 11:38 PM
77&79F250's Avatar
77&79F250
That green elec connector is the ignition key controlled power source for the factory stereo.
That is yellow with brown stripe and light blue with a red stripe, I do believe.
Old Jul 19, 2015 | 12:24 AM
bradphx's Avatar
bradphx
so I should connect the accessory wire to just the yellow and black right?
Old Jul 19, 2015 | 06:35 PM
bradphx's Avatar
bradphx
Should I cut and tape off the illumination wire?
Old Jul 21, 2015 | 10:31 PM
bradphx's Avatar
bradphx
Bump bump bump
Old Jul 27, 2015 | 07:27 AM
bradphx's Avatar
bradphx
So far...
Ok I charged up the battery and disconnected the stereo from the cig lighter and left it connected to the green connector that comes off the yellow/brown and light blue/red wires as pictured above. Still draining the battery. I'm debating just hooking it up to the fuse box as a last resort. At ideas??
