Third Brake Light
Got a newbie here...first post.
Installed a used fiberglass pick-up topper on my 2001 F150 Supercrew and for the life of me, I can not find a brake light wire in the rear trailer wiring harness to wire my third brake light. I have both the 4 flat and the large 6 round plug-in's at the rear bumper. I can only find a stop/turn combo wires for both the right and left turn w/stop, not just a stop light wire only.
Does anyone have an idea as to how and where I can pick-up a stop only wire for my third brake light to run to the topper??? Thanks in advance for your help!
Jim
C300 is located at the base of LH "B" pillar, that is by the drivers left hand if he drops his arm straight down while sitting in the drivers seat.
Jim
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
This wire is also accessable at C200 behind LH cowl panel, near your left foot.
Also at the Brake ON/OFF SWITCH AS WIRE # 511 Light Green.
And a good place if you have an automatic transmission and Speed Control is at the Clutch Pedal Position Switch Jumper as wire #511 Light Green.
DG = DARK GREEN and 569 is the ford wire number.
Ford has a standard set of colors and wire numbers they use for various applications and they use the same ones from year to year.
