Sponsored by: Real Truck
wiring topper stop light
Old Jun 10, 2010 | 07:38 PM
Blujay96's Avatar
Blujay96
Where do you hook up the topper stop light wire to in the back.
Old Jun 10, 2010 | 08:12 PM
rotun's Avatar
rotun
Reads ***** rules!
Look for the wire that is labeled "CHMSL", usually taped up to the rear of the wiring harness above the rear bumper.
Old Jun 11, 2010 | 05:55 AM
Blujay96's Avatar
Blujay96
When I bought the truck it had the wire hooked to a green wire behind the bumper. I do not see any label on the wire.
Old Jun 11, 2010 | 10:56 AM
rotun's Avatar
rotun
Reads ***** rules!
Maybe you can elaborate a little more on what you are trying to do?
Put a meter on those 2 wires and see if it gets V when the brake is applied.
Old Jun 11, 2010 | 11:33 AM
Blujay96's Avatar
Blujay96
I bought this truck with the topper on it but the upper brake light is not working. I checked the connection's. They have is wired with the ground hooked to the body of the truck behind the drivers side tail light and the power wire hooked up to a green wire with a black heat shrink cap on it that is located behind the bumper and just over the spare tire. I will try to check some voltage.
Bob R..
Jan 3, 2017 12:41 PM
stufarmer
May 20, 2016 04:08 PM
vtx1800
2004 - 2008 F150
Feb 28, 2010 10:54 AM
schpifford
Electrical Systems/Wiring
Nov 3, 2008 11:09 AM
joeskeeter
Feb 5, 2008 06:30 PM
