Starting problem - code PO320
Old Sep 27, 2005 | 09:56 AM
getrigged's Avatar
getrigged
My 96' E-150 5.0 engine has intermittent starting problems and at times stalls. Sometimes first thing in the morning it cranks without starting, then starts the second time. Other times it cranks time and time again with out ever starting. Some times it starts right up. The code reader shows PO320 (Ing/Dist Speed Input Circuit Malfunction). Distributer, roter, all plugs and wires are new and look good. Once I get into the engine to try to find the problem, it seems to start. Figure it's a bad connection, but am at a loss as to where. Any idea of what this code specifically referrs to and any advice?
Old Oct 4, 2005 | 08:54 PM
fkvbab's Avatar
fkvbab
crankshaft position [ckp] sensor/engine speed [rpm] sensor-circuit malfunction
probable cause wiring, CKP/RPM sensor, ecm
Old Oct 5, 2005 | 12:12 AM
getrigged's Avatar
getrigged
Red face Starting problem
Thanks for the reply. I finally talked with the local Ford guys who deal with codes and found out that the code PO320 basically points to a bad stater and/or modulater. With those two replaced, it seems trouble free now and shows no codes.
Old Jun 27, 2008 | 08:32 PM
BobL's Avatar
BobL
I'm having the same problem with my E150...please expand on the "bad stater and/or modulater. (where are they located?)
landscapeguy
6.2L V8
Jun 4, 2017 01:36 AM
I<3Ford
1983 - 2012 Ranger & B-Series
Jun 20, 2016 06:46 AM
RandyJ2007
1997 - 2003 F150
May 15, 2016 09:22 PM
tomeug69
Dec 10, 2015 08:48 PM
js2326
1997 - 2003 F150
Dec 31, 2003 06:46 PM
