Ranger Shaking at cold start
Old Jun 17, 2016 | 11:29 PM
I<3Ford's Avatar
I<3Ford
Hello
I have a problem with my Ford that I am hoping someone can help
I purchased a Ford Ranger from a single owner last year very good condition. It has about 320 000 on the odo
The truck was working perfectly the last year but recently started giving problems when I start up the engine (cold start).
Whenever it gets cold the engine would shake violently every 1-2 seconds during idling but stops when the engine is hot.
I also hear some scary sounds from the engine while it is shaking (only if I stand outside)
I have researched it and I can't find a solution, apparently it can be a lot of things as well as timing belts etc.
I had a mechanic change my timing belt a few months ago along with a major service. I am very scared something might go wrong with the engine. Can anyone please help?
Make, FORD Ranger
Model, 2008 Montana
Engine 2.5 tdi
Mileage 320 000
2x4
Old Jun 18, 2016 | 08:44 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
The noise not being there after the engine warms up is a good clue, but with the mileage on this puppy, unknown maintenance, service, or repair history, several suspect things come to mind, so we need some more info to suggest some suspects.
Did the noise begin slowly over time, or suddenly after some event??? Like after the timing belt replacement, or other repair, or say after a oil & filter change????
Use your stethoscope, or rig one from a length of rubber hose, or tubing, or a wooden broom handle, one end to your ear, the other on the suspect noise area & try to determine where in, or on the engine the noise is emanating from, like up top, midway, or low down toward the oil pan, where it seems to be the loudest & what kind of noise it seems to be, like a tick, thump, clunk, screech, metallic, rubber, well you get the idea, as that can help the forum get our collective minds & experience together to make our best guess as to what we believe belongs on your suspect list & what next are the best options.
Was the timing belt tensioner & idler pulley also replaced with the new timing belt & were they OEM/Ford, or after market parts, if after market, what brand parts were used????
Some thoughts to get your trouble shoot started.
Old Jun 18, 2016 | 06:33 PM
Kruse's Avatar
Kruse
Fuel injector that is leaking down?
Old Jun 20, 2016 | 05:25 AM
I<3Ford's Avatar
I<3Ford
Thanks for your replies, I will make observations as you suggested and update on the results. Hopefully its nothing serious
Old Jun 20, 2016 | 06:46 AM
pawpaw's Avatar
pawpaw
If you have a CEL lit, the computer will have a set trouble code/s stored, so have the computer/s scanned for trouble code clues & post All code Numbers, as they can help focus & shorten a trouble shoot.
If you don't have a code reader, or scan tool, most auto parts stores will scan the computer at no charge if the CEL is lit.
From your description & the mileage on this puppy you may have more than one problem, noise is mechanical, the miss could be from that, or maybe electrical, from faulty high voltage break down in secondary ignition components, like spark plugs, wires, coil pack. The noise could be a number of things from a sticking valve, to an oil pressure problem, so you can see we need more good clues to help zero in on possible suspects.
cmejia1231
2004 - 2008 F150
Apr 17, 2017 12:50 PM
bigbluetruck
Aug 2, 2012 03:37 PM
walkman
19
Dec 8, 2006 12:24 PM
rodwrencher
4 Cylinder Engines
Nov 6, 2005 06:31 PM
Msp541
Jul 15, 2004 10:49 PM
