Codes PO401, PO174, PO308
Hi, I have a 1998 Ford F-150 4x4 4.6 142000 miles. It has started missing and running bad part of the time and running fine at times. It runs bad mostly when you first crank it and while the engine is warming up. Sometimes after the temp gets up it clears up but not always. I got these three codes: PO 401, PO 174, PO 308. I changed the spark plugs and fuel filter today. That didnt help. Any ideas?
Joe
Joe
Hello
P401
Possible causes:
Fault in vacuum supply to EGR vacuum regulator solenoid.
EGR valve stuck closed or iced.
EGR valve diaphragm leaks.
EGR valve or flow path restricted.
EGR vacuum hose off, plugged or leaks.
VPWR circuit open to EGR vacuum regulator solenoid.
EGRVR circuit to PCM open.
EGRVR circuit to PCM shorted to PWR.
Differential pressure feedback EGR (D.P.F. EGR) sensor pressure hoses both connected improperly.
D.P.F. EGR sensor pressure hoses reversed.
D.P.F. EGR sensor VREF circuit open.
Downstream pressure hose off.
Downstream pressure hose plugged.
Damaged orifice tube assembly.
Damaged EGR vacuum regulator solenoid.
Damaged D.P.F. EGR sensor.
Damaged PCM.
P 174
DTC P0174 bank 2 indicate the fuel/air ratio is too lean. The fuel trim system is at the rich correction limit.
Fuel system
Excessive fuel pressure.
Leaking fuel injector(s).
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Contaminated fuel injector(s).
Vapor management valve (VMV) leaking.
Induction system
Air leaks after the MAF.
Vacuum leaks (vacuum lines and gaskets).
Restricted air inlet.
PCV system.
Fuel purge system.
Improperly seated engine oil dipstick.
EGR System
leaking gasket.
Stuck open EGR valve.
Leaking diaphragm.
Base engine
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2S(s).
Check intake air system for leaks, obstructions and damage.
Check air cleaner element, air cleaner housing for blockage.
Verify integrity of the PCV system.
Check for vacuum leaks.
P401
Possible causes:
Damaged PCM.
P 174
Fuel system
Induction system
PCV system.
Fuel purge system.
EGR System
leaking gasket.
Leaking diaphragm.
Base engine
Oil overfill.
Cam timing.
P0308 - Cyl No.8, Fuel Inj. Test Pin 98
HD1 CHECK POSSIBLE CAUSES OF MISFIRE
Note: Running out of fuel can turn on the MIL and possibly store a Continuous Misfire DTC.
Misfire Continuous Memory Diagnostic Trouble Codes (DTCs):
Possible causes:
Ignition system.
Fuel injectors.
Fuel pressure.
Evaporative Emission System.
EVAP canister purge valve.
Base engine.
Running out of fuel
There U go !
Look at all these areas and U should find the problem.
Possible causes:
Ignition system.
Fuel injectors.
Fuel pressure.
Base engine.
Running out of fuel
There U go !
I would start with fixing the P0308 first as it can cause the P0174.
Get rid of the miss before you worry about anything else.
If the plug didnt fix it I would try a new plug wire.
The P0401 is probably caused by a bad DPFE sensor but could also be a bad EGR valve or plugged EGR ports in the intake.
If you do a search here you'll find lots of info on the P0401 and what others have done to cure it.
stevekantercool
02-18-2017 03:47 AM
RandyJ2007
1997 - 2003 F150
05-15-2016 09:22 PM
Mr f250
02-21-2016 11:25 PM
billyboycurran
1997 - 2003 F150
02-05-2011 08:42 PM
