Overhead console problems.
Old Sep 26, 2005 | 11:47 PM
texas_vet's Avatar
texas_vet
hello all.
I have read in the past about poor soldering on the circuit boards causing overhead monitors to go out. I had one go bad and did not check the soldering because it was before i had read your posts on the problem. But one of the mech. here at the ford dealer does a lot of my work on my diesel 250 at his home hooked me up with a new one real cheap but told me that they have alot of them that goes out because of the heat off of the roof. there is no insulation above the circuit board and when we put the new one inhe put some insulation on top of it and said that would help alot. I thought I would pass this on to all of you, Dont know if it is true but stands to reason. cant hurt. Thanks for all the good info guys.
Old Sep 29, 2005 | 05:35 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Excellent idea. I'm definitely going to try that once I get mine soldered up.
Old Sep 29, 2005 | 06:04 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
thanks for the idea. i will defanitely put some up there if i ever happen to visit that loacation.
Chemfrk
Nov 19, 2011 04:00 PM
Elmo154
Jul 17, 2011 07:41 PM
b4hntn
1978 - 1996 Big Bronco
Mar 31, 2010 06:39 AM
DaveG67
1997 - 2003 F150
Nov 27, 2009 03:06 PM
