1978 - 1996 Big Bronco
Overhead Compass Thermometer Temp
Old Mar 30, 2010 | 06:52 AM
b4hntn's Avatar
b4hntn
My compass/temp died over a year ago. Remedies are scarce and widely scattered across the Internet. Most suggest re-soldering the resistors because they break loose. Module removal was easy on my 94. T10 Torx and nail file are not needed. All you need is a Phillips to three screws then four to disassemble.
After inspecting the printed circuit board using many different lights and magnification and probing with a tooth pick I see nothing suspicious. Everything seems to have a nice bubble of shiny solder. The resistors are about the size of a match head and none of the 40 or so appear to be loose. There is discoloration of the board around the component that has a heat sink and what I am guessing to be a capacitor next to it, but with the heat sink there that may be normal heat???
I was not good at soldering fifty years ago and will not attempt solder joints that require magnification to see. I'm going to clean the two connectors and reinstall as that worked for one guy.
Thoughts?
Old Mar 30, 2010 | 02:53 PM
b4hntn's Avatar
b4hntn
No luck. I think a capacitor is fried. Getting it in the sunlight with a magnifying glass the 120 uF 6 v capacitor area is really dark. Turning the board over, the area near the capacitor is discolored also. I reinstalled everything and there is no improvement. The display is dead but my map lights still work.
This project is tabled until I find someone who can replace the capacitor and see if that fixes it.
Old Mar 30, 2010 | 11:30 PM
94 XLT White/ Silver 302's Avatar
The Explorer's use the same electronics as the Bronco. Usually you can pick up an Explorer console fairly cheap. Kenny
Old Mar 31, 2010 | 06:39 AM
b4hntn's Avatar
b4hntn
Thanks for the info. I don't find the module on eBay but see lots of explorer overhead consoles. Glad to know they have the same module, compass and temp.
kailor
43
Jan 20, 2017 03:58 PM
ol blue 97
1997 - 2003 F150
Aug 8, 2016 01:44 PM
Tim Hodgson
Electrical Systems/Wiring
Oct 31, 2015 08:36 PM
Finally Powerstrokin
37
Mar 8, 2012 07:12 PM
hamoyer
Apr 2, 2010 09:04 AM
