Guys:
How many of you have OR attempted a twin stick conversion on yr truck? How hard is it and where would I get the parts? Can i make the linkage myself? Furthermore, what will be the advantage if I install one? Thanks a bunch!
A twin stick conversion is done so that you can control the front and rear axle seprately example you could put the front axle in 4H and the rear axle in nutral say if you break a axle shaft
but you dont want to ever put the front in High and the rear in Low if you do something will break
John Workman
76 F250 Crew Cab Short Bed
4x4 460 C6 Dana 60 F/R
Jsworkman@mybluelight.com
