Offroad & 4x4
twin stick?
Old Aug 28, 2007 | 07:16 PM
madmatt81's Avatar
madmatt81
twin stick?
i'm looking for a twin stick for a 205 in a 78 f250. who makes a good kit for this? do u guys make your own? how hard is this mod?
Old Aug 28, 2007 | 07:29 PM
75F350's Avatar
75F350
Had a home made unit that I made from a honda civic aluminum strut brace. Cut it in half and created a pivot, blah, blah, blah.
I have an Advance Adapters cable set-up now.
Old Aug 28, 2007 | 08:32 PM
79-400-POWER's Avatar
79-400-POWER
I made my own using 2 old shifters i had laying in the shop.
Old Aug 28, 2007 | 08:57 PM
fishmanndotcom's Avatar
fishmanndotcom
ditto but if i had to do it over i would go the cable set-up
-cutts-
Old Aug 28, 2007 | 09:06 PM
RawPower's Avatar
RawPower
-cutts-
Hmm thats interesting... why?
Getting ready to do this, so I would like to know
Old Aug 28, 2007 | 09:19 PM
fishmanndotcom
building the mounts on my bronco was a PITA! there is no room! if i had done the cable setup it would take half as much to mount
-cutts-
Old Aug 29, 2007 | 12:32 AM
wvmudder's Avatar
wvmudder
I made my own twin sticks using two stock 78 np205 shifters. Each shifter has to have its spacer cut down till both shifters fit on the one mounting bolt. I then used I think, 3/8 metal rod to make the links from shifter to shift rails. This method will require some trimming of the transmission tunnel to fit, but it works great.
I am now in the process of trying to peice two boots together to fit the shifters, if this fails, i'll try the dual shifter boot thats available for the jeeps.
Its pretty cool putting the front axle in gear (rear in neutral) and making sharp turns in the mud to line up with on another hole. But be warned, it might be pretty hard on anything less than a D60, im using rockwells.
Hope this helps, Dave.
78 PEB
15
Nov 4, 2015 07:34 AM
ozzy460
Offroad & 4x4
Apr 7, 2008 01:56 AM
Homelessduck
Mar 14, 2007 03:51 PM
ClatonK
Oct 31, 2005 09:17 PM
