Help With Codes??
Old Sep 23, 2005 | 12:04 PM
fordracerman's Avatar
fordracerman
Help With Codes??
i have a 2001 7.3 , went out to start this morning,started good. went and had a shower to let her warm up, came out and it had stalled?? tried again and no start. hooked up programmer and got these codes. p1249,p1212,p0340,p1211 any body have a list of codes so i could check these out. thanks any help would be appriciated.
koby
Old Sep 23, 2005 | 12:17 PM
mech2161's Avatar
mech2161
P0340- CMP sensor circuit malfunction
P01211- ICP not controllable - pressure above/below desired
P01212- ICP voltage not at expected level
P01249- wastegate fail steady state test
Old Sep 23, 2005 | 12:22 PM
wlihntr's Avatar
wlihntr
you probably have a bad "cam position sensor"
fordracerman
hard starting??
i let it sit for awhile and tried to start it again and the batteries are dead??? could this be the problem causing all the codes??? any help would greatly help my battle.lol thanks again
Old Sep 23, 2005 | 12:23 PM
fordracerman
i just did one earlier this year!! could it be bad already??
Old Sep 23, 2005 | 12:34 PM
wlihntr's Avatar
wlihntr
it could, that first code "CMP (CaM Position) sensor circuit malfunction" is a pretty good indication.
Old Sep 23, 2005 | 03:35 PM
fordracerman
anyone know how to check a cps?? with it out on the bench?? thanks
Old Sep 23, 2005 | 03:41 PM
mech2161's Avatar
mech2161
Check it on an AC scale multimeter. Pass a piece of metal (screwdriver) past the end. If it bounces the meter it is working.
Old Sep 23, 2005 | 03:54 PM
fordracerman
im just hoping the code i read is a old code from when i had the cps changed earlier this year. im going to try and find the cps and remove it and test it out before getting a new one lol.
Old Sep 23, 2005 | 08:59 PM
chevskeezy's Avatar
chevskeezy
hey everybody just thought id throw in my 2 cents this is my first post on here but ive been reading ford-trucks for a while im a diesel tech at a ford dealership i pulled my truck in yesterday after work for the same reason after hooking it up to the WDS i pulled B1483 which is a body code for the brake on/off switch abnormal signal B1203 which is fuel sender circuit short to batt PO 340 and PO 344 and a whole bunch of overboost codes usually when i need to replace a cmp is has the 340 and the 344 which are both cmp codes there are other circumstances when only one code will be present and the sensor will not always need to be replaced its kinda 50/50 it might need replaced or it migh be some other problem. if you took it to a ford dealership the codes should have been cleared its part of the process to verify the correction so it might be a new code- just my 2 cents
Old Sep 23, 2005 | 09:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthsiasts and the 7.3 forum chevskeezy.
Old Sep 23, 2005 | 09:39 PM
fordracerman
charged batteries and tried to start. fired right up but runs very very rough and wont idle up much.im way overdue on oil service, could this be a problem with proper oil pressure signal?? any ideas peeps, i really dont wanna do the cps if no need but will if i have too.
thanks all
koby
Old Sep 23, 2005 | 10:25 PM
BIGRED7.3's Avatar
BIGRED7.3
just a thought, have you checked the injector harness that plugs in on the top side of the valve covers? mine did this and i had to replace them. sometimes you get dirt in there and can clean them to get a good contact.
Mrdbraun
May 17, 2016 11:19 AM
tidexp
23
Sep 9, 2012 08:37 PM
lukeg
Apr 9, 2012 07:48 PM
onGlue
Oct 5, 2010 09:52 PM
bosshoss
1983 - 2012 Ranger & B-Series
Apr 22, 2004 07:21 PM
