Tail Gate
Old Sep 22, 2005 | 05:35 PM
dell's Avatar
dell
Tail Gate
My son in law has a Ford F-250 7.3 Power Stroke. His tail gate will not come down. I know Fords are a little notorious for this. But I don't have a clue as to how to work on the 96's and pop the thing down. It seems to be sealed up pretty good! I mean do I have to take to tail light out to get to it or something? Does any one have any suggestions?
Old Sep 22, 2005 | 07:59 PM
husker's Avatar
husker
Not to be silly, but mine has a lock on it. Is it locked. The lock uses the ignition key to lock it and is next to the release handle. Also when I bought my truck (used) I had to jerk the tail gate pretty hard to get it to release. A little lubrication of the latches at the side and wd40 in the release handle area loosened things up a bunch. Now it opens without a problem. Good luck.
Old Sep 22, 2005 | 08:39 PM
dell's Avatar
dell
Husker, thanks for the response but no it's not a locking tail gate. I did spray some wd40 on it and on the latch areas and the handle. With someone opening the handle I even got up in the bed and kicked it a few times but nothing.
Old Sep 22, 2005 | 09:32 PM
twildman's Avatar
twildman
You want to put the pressure on the outside of the tailgate, pushin in. Get a rubber mallet also and pull up on the handle while pushin on the gate and then pound the pissouttait a time or three and see what happens
Old Sep 22, 2005 | 10:48 PM
believer45's Avatar
believer45
If yours is like mine (95) there is a panel on the inside of the tailgate about 30" x 10" held in with screws. If you pull that panel off you should be able to access the linkages and get your tailgate open.
Dave / Believer45
Old Sep 23, 2005 | 05:02 PM
blessteve's Avatar
blessteve
You must do tailgate maintance. Once a month you must open tailgate sit on it and drink beer and shoot guns. Do this and it will work fine for the life of truck.
Old Sep 23, 2005 | 05:07 PM
dell's Avatar
dell
beleiver45, by panel, I assume that you mean part of the bed liner that cover the tail gate? Or are you talking about the back side of the tail gate itself? Are you saying to take the tail gate apart to get to the linkages?
Old Sep 23, 2005 | 05:25 PM
GarrettShields's Avatar
GarrettShields
Try spraying WD40 in the hinges with it closed and near the handle as well.
Old Sep 23, 2005 | 05:32 PM
ford390gashog's Avatar
ford390gashog
yes take it apart. if there is a bed liner remove it. under it is the access panel open it and operate the linkage by hand.
Old Sep 23, 2005 | 07:56 PM
husker's Avatar
husker
Dell, sorry about the lock stuff. I noticed after I posted that you were referencing a 96 and mine is an 01. Good luck getttng it to work. Let us know if you get it fixed and how.
Old Sep 23, 2005 | 10:42 PM
believer45's Avatar
believer45
If you have a drop-in bedliner with the tailgate protector remove the tailgate protector and you will see the panel I referred to. If you have a spray in bedliner with the tailgate also sprayed the access panel and its screws have probably been sprayed in place. Still removal is the same, just harder.
Dave / Believer45
Old Sep 23, 2005 | 11:10 PM
82F100SWB's Avatar
82F100SWB
What's probably wrong is the bracket that the tailgate handle bolts to is bent outwards(handle was out a bit at the bottom.) My '00 F250 was like that. Took the handle off, got out the hammer and a 2x4' and bent it back in so that the handle sat flush, and it worked like brand new.
