89 351W roller cam??
Old Sep 20, 2005 | 07:39 PM
Mr. Bob's Avatar
Mr. Bob
This is a non roller block, but am looking into what it takes to put a roller cam in there...
Its going into a 1991 F250 soon to be on 44s...
Its also going to be a 408 stroker and carbed, so its not needing an FI cam...
here is my question, do I need to put those special roller lifters in there for a non roller block, or is is possible to use 302 roller lifters, drill and tap 2 holes in the block for a retainer plate, use the FRPP tie bars and retainer plate kit?? Does the non roller block have deep enough lifter bores to do this???
Im not too sure whats all involved yet, so help would be really great!!!
thanks!!
Bob
Old Sep 20, 2005 | 09:56 PM
Blurry94's Avatar
Blurry94
A few guys with 351's have drilled tapped the block for the spider on their non-roller blocks without any outside issues. These guys are using the spider, lifters, and dogbones from a 5.0 Mustang for their conversion as well.
Old Sep 20, 2005 | 11:05 PM
Mr. Bob's Avatar
Mr. Bob
yeah... thats what I like to hear!!! Is that using a cam designed for a roller HO aswell??? AKA a roller cam described as a replacement for a roller cam, and not one for a non roller cam??
Old Sep 21, 2005 | 12:15 AM
cjjeeper85's Avatar
cjjeeper85
The cam will need to have a reduced base circle.
Old Sep 21, 2005 | 12:52 AM
F150 hybred's Avatar
F150 hybred
k... the other difference between a roller and non roller block is the tops of the lifter bores..on a "factory" roller block, there is a relief machined for the "dog bones" ... on a non roller there is none... also, the spider mounting holes, (but we covered that earlier). Look to see EXACTLY what you have. If you need to use aftermarket lifters, make shure they use a tie rod for locating. Or you could get the local machine shop to machine the block for you.
Old Sep 21, 2005 | 05:42 AM
Matt95L's Avatar
Matt95L
You can either get a reduced base circle cam and use the standard roller lifters,spider,and dogbone or you can get the link bar lifters and run a standard base circle roller cam.
Old Oct 9, 2005 | 05:47 AM
Katmandu's Avatar
Katmandu
Question
How does one go about tapping out the holes for the Spider ??
billyrayf150
Feb 13, 2016 11:50 AM
71f100s
16
Oct 1, 2014 12:48 PM
LindenBruce
Mar 10, 2010 08:57 AM
76 F150 Ranger XLT
25
Oct 29, 2004 11:55 AM
dbc
May 4, 2003 10:53 PM
