Steering Column Components
Old Jul 25, 2002 | 12:43 PM
petem's Avatar
petem
My '76 F250 4x4 makes a clicking noise inside the column when I turn the wheel side-to-side and makes the same noise when I hit a bump in the road. I want to pull the steering wheel anyway to repair/replace turn signal switch and to address the AT shift pawl(it pops out of Park!). Are there some bearings inside the column that I can replace? Could that be the cause of the noise?
Old Jul 25, 2002 | 02:11 PM
beartracks's Avatar
beartracks
Not sure about the noise. The park pall is in the tranny although there is a "sector" plate in the column. There is also a bearing in there. I used a washer to eliminate the up and down play in mine.
Old Jul 25, 2002 | 05:28 PM
petem's Avatar
petem
Ok-hmmm. Then my sector plate is worn out, because none of the lockouts work. I can pull the sector handle down out of park w/o having to pull back on it simultaneously. Hopefully I will find the noise after pulling the wheel. Thanks for the help!
Old Jul 25, 2002 | 07:11 PM
par0250's Avatar
par0250
Gangley
Sep 26, 2013 08:42 AM
pursugr
1997 - 2003 F150
Feb 23, 2007 10:31 AM
sereeves
Sep 7, 2005 07:44 PM
tvvbsn
1997 - 2003 F150
Apr 1, 2005 11:14 AM
texcon
Jun 16, 2004 09:25 PM
