voltage??
Old Jul 23, 2002 | 11:30 AM
76_F150_390's Avatar
76_F150_390
voltage??
how much voltage should my pickup coil in my dist. be putting out on my 76 with a 390????
Old Jul 23, 2002 | 12:39 PM
Mil1ion's Avatar
Mil1ion
voltage??
See below
[link:www.tispecialty.com/articles/article4.htm|Read Me]
[font color=red]Dennis
FTE Assistant Adminstrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 23, 2002 | 01:35 PM
76_F150_390
voltage??
maybe I didn't understand it right...but that didn't answer my question at all??? I was looking more for a number of some sort???
Old Jul 23, 2002 | 09:47 PM
Mike W's Avatar
Mike W
voltage??
The shop manual said to use a meter on the 2.5 volt range on the leads (unpluged and probably a analog meter).If the meter oscillates with the engine cranking, the distributor is ok. Also, the resistence must be between 400 to 800 ohms. I put an oscilloscope on one and I think I had about 3v peak to peak ac.
Old Jul 24, 2002 | 10:29 AM
76_F150_390
voltage??
Thanks for the help.
I am getting the right resistance (about 624 ohms). But I am only getting about .8 peak volts. Would this be enough to give my engine a little spark or is this why I have no spark at all??
Old Jul 24, 2002 | 09:39 PM
Mike W's Avatar
Mike W
voltage??
What are you using to measure the voltage? If the resistence is good, the distributor is probably fine.
Old Jul 25, 2002 | 07:22 PM
76_F150_390
voltage??
I am using a Fluke 77 series II multimeter...the ac voltage setting.
The resistance from orange to purple is correct...but my chilton says that when I measure it from purple to ground or orange to ground there should be 70,000 or more ohms. But I get no resistance.
I have ran all these tests multiple times. And everything else checks out ok... 13.8v coming from battery into coil and 6.8v coming from ignition module. And I am running a plug wire (that I know is good)directly from the coil.
I have no clue on what is wrong...ANY help/advice/suggestion wanted!!!
Old Jul 25, 2002 | 07:32 PM
sparky's Avatar
sparky
voltage??
Do you mean no resistance as in "0" or as in you cant measure any resistance??
"0" is bad wire grounded, or short as so many people like to call it
Cant measure any resistance is good as that is way over 70,000 ohms.
Sparky
Old Jul 25, 2002 | 10:24 PM
Mike W's Avatar
Mike W
voltage??
Yeah, your Fluke is seeing an open, resistence is too high to measure, which is good. Your voltage of .8 on the Fluke would be 1.131 peak or 2.262 peak to peak which is about what I saw on a oscilloscope.
The 3rd wire going into the distributor is the system ground. I would check it to make sure it is really grounded.
Old Jul 25, 2002 | 10:40 PM
Mike W's Avatar
Mike W
voltage??
