351 trans suggestions, Please look here, I need help fast, by tommorow maybe
Right now my 351 is backed by a C6. I found a five speed with bell housing, clutch, and pedal, plus all hardware for $100. The only problem is the transmission is on a '86 or so 300 inline six. Is the bell housing the same on the engines? I heard that the 300 bell housing would bolt up to a 351C and I also heard that a 351C bell housing would bolt to a 351W. Would this transmission be strong enough for my application even if it did fit?
Motorhead351 posted this in another topic.
The mazda gearing is as follows:
1st - 3.90
2nd - 2.25
3rd - 1.50
4th - 1.00
5th - .80
ZF:
1st - 5.72
2nd - 2.94
3rd - 1.61
4th - 1.00
5th - .76
If it is a ZF and you do not want it, send me a message and I will jump on it in a heartbeat!
If you look up M5OD and Ford ZF on eBay you will be able to find pictures of both. That should help educate you.
If it is from the early 80's it could also be a T-18 or T-19. Reading more in the transmission forums might help you out a bit with those.
Mike
1st - 3.90
2nd - 2.25
3rd - 1.50
4th - 1.00
5th - .80
ZF:
1st - 5.72
2nd - 2.94
3rd - 1.61
4th - 1.00
5th - .76
Mike
Louisville Joe
13
10-08-2010 02:00 PM
80-F-250
06-10-2006 12:07 PM
