Brake plumbing progress
Old Sep 18, 2005 | 07:53 PM
Putt's Avatar
Putt
Talking Brake plumbing progress
Well I finally got some time to work on the '66. I replumbed the front brake lines to the prop/metering valve and mounted the valve today.
I will tackle the prop valve to master cylinder lines next I hope to have some life in the ol' truck soon!! It's time to get the disc brake hardware so I can install the calipers and rotors.
How are your projects going??
Old Sep 18, 2005 | 08:56 PM
mikecarson's Avatar
mikecarson
Mines progressing, working on my frame mounts now.
Got the CV brakes and steering column mounted, though the CV booster is HUGE. Need to get a smaller diameter booster so I'll have room to run the computer lead where I want it.
I'll post some progress pics next weekend, got two rolls to sort through.
Old Sep 19, 2005 | 06:18 AM
William's Avatar
William
Putt, Where did you mount the prop valve?
Old Sep 19, 2005 | 07:24 AM
Putt's Avatar
Putt
William, I mounted it to the inside of the frame between the riveted crossmember and the transmission crossmember. It is a little tight for the lines, but it was the best place I could find! I can reach all the fittings, just getting them bent to line up with the ports is difficult.
Mike, glad to hear that progress is being made!
Old Sep 19, 2005 | 07:40 AM
William's Avatar
William
That is where I'll put mine. The engine and transmission are out and I have removed the crossmember and steering gear as well. Working in this area should be easy now!
Old Sep 19, 2005 | 07:44 AM
Putt's Avatar
Putt
I forgot to mention that I spaced it out about a half inch with some short pieces of tubing to clear my 1/2" fuel line. It has also made the connecting of lines easier, there is room for the wrench to turn without hitting the frame.
That isn't fair!!! It should be a breeze with all that hardware out of the way! Good luck.
Old Sep 22, 2005 | 12:17 AM
Putt's Avatar
Putt
Thumbs up Another step!
Well I managed to get the lines run from the master to the prop valve today, I should be able to hook the rear line up next time.
Old Sep 22, 2005 | 07:17 AM
William's Avatar
William
Good tip about the spacer! I had not thought of that. Thanks! With everything off this should be a fairly uncomplicated deal.
elkarcher1716
Dec 8, 2013 04:54 PM
lafermedavid
Dec 1, 2012 06:13 AM
finneys98xj
Apr 12, 2012 02:12 PM
kev78
Feb 6, 2011 04:30 PM
Ra_
Jun 20, 2008 08:19 PM
