'71 tie rod end problem
Old Sep 17, 2005 | 07:03 PM
gp's Avatar
gp
I have a dead inner tie rod end. 1971 2WD. The problem is: in Australia the Ford factory attach an Australian I.D. plate which does not contain the serial No. that would appear in the states. I have a catalog from LMC which tells me that the part could be one of two possiblities, identifiable by the serial # which I don't have. I need another solution to identify the correct part. Any alternative suggestions? I have also read with interest, some forum feedback regarding purchases from LMC. Some of the comments are not kind. Any thoughts for a new player?
Old Sep 17, 2005 | 07:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Sep 17, 2005 | 07:37 PM
gp's Avatar
gp
Thank you. For future reference, how do I edit posts?
Old Sep 17, 2005 | 08:07 PM
4Cammer72's Avatar
4Cammer72
when you post your reply or thread opener and submit it the new page will have the edit tab at the bottom right side of the page. next to where it says quote
Old Sep 17, 2005 | 08:56 PM
gp's Avatar
gp
Thanks . I'll get used to it eventually.
Old Sep 18, 2005 | 01:11 AM
WillyB's Avatar
WillyB
The edit feature is only good for about an hour after you post - after that you can not edit your post. For instance, you can't edit your original post now. The edit button will disappear when it times out.
I suggest you post a picture of your part, maybe someone can identify it as being the same on their truck.
As to LMC, I have never had a problem with them.
Old Sep 18, 2005 | 01:40 AM
Ford_Six's Avatar
Ford_Six
The earlier one has a length of 29.5" (749.3mm)from the tapered hole to the stud center, while the later one is 30.7" (779.8mm).
revhead64
May 8, 2021 11:16 AM
Towmonger
Jun 22, 2014 07:18 PM
aussiecowboy
17
May 25, 2014 07:47 PM
jazzygreen
13
Jul 8, 2013 11:41 PM
nairod
13
Feb 26, 2009 11:23 PM
