92 explorer code 543
Old Sep 17, 2005 | 01:49 PM
marthabefd's Avatar
marthabefd
secondary circut does this mean the pump is bad? or a short in the wiring?
i can hear the pump when the key is turned on. any help please thanks
Old Sep 17, 2005 | 03:50 PM
aggyaggy's Avatar
aggyaggy
543 is a circuit malfunction .Check your inertia fuel shut-off switch and associated wires.Then check your fuel pump relay and its wiring.
Old Sep 17, 2005 | 06:12 PM
mrshorty's Avatar
mrshorty
KOEO 543 or CM 543? A KOEO 543, and the pump running suggests that the wiring fault is between the computer and the actual fuel pump circuit. A CM 543 could indicate that the fuel pump circuit is intermittently cutting out.
Old Sep 18, 2005 | 08:24 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Code 543 is "Fuel pump circuit open connection - ECA/Electronic Control Assembly to battery."
I'd suspect a bad FP relay, that's 'chattering' and giving an intermittant circuit. You can exchange the FP relay with the A/C clutch relay, to check it.
Old Sep 18, 2005 | 10:13 PM
Jharger's Avatar
Jharger
No way. Not ever here in Phoenix where it is still 100+ highs in mid September would anyone want to sacrafice AC over an engine that actually runs.
Little humor folks...But I am still sweating my A thing off working in the garage.
I think the lone ranger speaks of good wisdom.
Old Sep 18, 2005 | 10:27 PM
marthabefd's Avatar
marthabefd
It is a CM code can I still exchange the ac relay for the fp?? any other
things to look for?? thanks
Old Sep 18, 2005 | 10:37 PM
marthabefd's Avatar
marthabefd
already cleaned the ground wires and cleared the codes. and replaced the battery just due to age no other reason. Do I just pull the ac relay and insert it in the fp slot?? thanks
Old Sep 19, 2005 | 10:04 AM
thelonerangerxlt
Yes, Martha, just switch them around. They're the exact same type relays. Clear the codes, and see if they come back with the relays switched. If they don't, then a new relay is in order (for the A/C). If they do come back, then the trouble lies elsewhere.....
Old Sep 19, 2005 | 11:31 AM
marthabefd's Avatar
marthabefd
Thank you I will try tonight and posst the results.
Old Sep 20, 2005 | 12:25 AM
Jharger's Avatar
Jharger
Well ? - I came on line just to see your results...
Ratsmoker
Jan 1, 2003 08:10 PM
Franklin2
Jun 16, 2002 04:37 PM
dinosaurfan
Oil & Lubrication
May 29, 2002 12:32 PM
pcmenten
May 14, 2002 08:33 AM
Mikal
Nov 21, 2001 07:17 PM
