I hate dealers
Old Jul 31, 2002 | 11:45 AM
Big Bad 1Ton's Avatar
Big Bad 1Ton
I hate dealers
I am in need of a part number for the upper metal inserts for the cab mounts. the local dealer says it is to old and they can't look it up, but if i have a part number they maybe can find it. anyhelp????
Old Jul 31, 2002 | 01:31 PM
Graffe's Avatar
Graffe
I hate dealers
[updated:LAST EDITED ON 31-Jul-02 AT 02:32 PM (EST)]Are you speaking of the small inspection plate? I'll throw a few numbers at you to see if any help:
Front Cab Mount Right: C5TZ-10112A70
Front Cab Mount Left : C5TZ-10112A71
Cab Mount Inspection Plate: C5TZ-81111B80-A (for both left & right)
Hope that helps you. If not, if you can describe the part a bit more I'll see what my brain can come up with.
Graffe
Old Jul 31, 2002 | 01:41 PM
Big Bad 1Ton
I hate dealers
there are 2 metal pieces that go inside the cab mount bushings, the bottom has the nut and the top just slides inside the bushings
not knowing that i needed to reuse them i found out that my new Royobi Cordless Sawzall works great
Old Jul 31, 2002 | 02:12 PM
Graffe's Avatar
Graffe
I hate dealers
>inside the bushings
If those are the pieces you are looking for, then you may have to fabricate something or get them from a donor truck. I believe that Ford only sells the mounting bolts and bushings as a kit. That number is:
D3TZ-5400-S
Graffe.
Old Jul 31, 2002 | 02:16 PM
Big Bad 1Ton
I hate dealers
thats what i was afraid of. Thanks for the help (maybe they come in the bushing kit if it aint to expensive)
Old Jul 31, 2002 | 02:44 PM
Graffe's Avatar
Graffe
I hate dealers
This is what comes in the factory kit just for your reference -
http://www.oklumber.com/F250/cab_mount_kit.gif
I can see the pieces you are after. Ain't sawzall's great?
Graffe.
Old Jul 31, 2002 | 05:15 PM
Vampiro's Avatar
Vampiro
I hate dealers
try looking through motorhaven for them
Old Jul 31, 2002 | 06:21 PM
Silentheero's Avatar
Silentheero
I hate dealers
Dealers are only good for buying the new cars and driving them as fast as you can from the lot!!! I went to them for a stock amp for a 90 taurus but they did not make them anymore (shock!) and to make another would only cost 900 DOLLARS!!!!!!!!!!!
:-staun
Preserve cartoons, Watch Anime!
Old Aug 1, 2002 | 08:55 AM
Big Bad 1Ton
I hate dealers
I didn't see them in the book but i will look later today when i get home. Going to the beach this weekend so I am taking a note pad and a pen. have no use for a calculator cause i don't wanna know what i am spending
lo
General Automotive Discussion
May 31, 2012 06:15 AM
F2502011
6.7L Power Stroke Diesel
Feb 12, 2011 09:34 AM
2003 EXCURSION
Oct 7, 2009 07:16 PM
matty169
Apr 2, 2009 10:06 AM
boing70
Jun 30, 2007 04:28 PM
