Voltage Regulator Part number
Old Jun 29, 2007 | 03:48 PM
boing70's Avatar
boing70
I have a 1994 turbo IDI, Dealer parts guy quoted me $120 bucks I need a part number to get the right one and not pay an extra $100 can anyone help me out?
Thanks
Old Jun 29, 2007 | 03:55 PM
78sharpshooter's Avatar
78sharpshooter
that sounds like too much money! go to rock auto website and they appear to be much cheaper.
Old Jun 29, 2007 | 11:37 PM
Brimmstone's Avatar
Brimmstone
Try your local parts store. Depending on which one it takes it can be anywhere from 14 dollars to over 160 dollars. What does it look like and what alternator do you have. The old style regulator that mounts on the fender is the cheapest. If you have a Leece-Neville they get pricy but not as bad as a Bosch. I will recommend however if you have the one that mounts on the fender make sure you have a good ground from the regulator body to a good ground point.
Old Jun 30, 2007 | 02:12 AM
boing's Avatar
boing
Until today I thought they were all on the fender. I am going to look into this tomorrow and try to figure this out.
Old Jun 30, 2007 | 01:01 PM
boing's Avatar
boing
Woops I am both boing and boing70 I was on another computer yesterday and forgot my login info
Ok I just checked the batterys with the truck turned off and both were 12.56 volts and with the truck started they were both at 14.xx volts each.
I am now thinking that my starter is going. When I start the truck it is very sluggish almost like the batterys are low(they are both new).
What do you guys think?
Old Jun 30, 2007 | 04:28 PM
Brimmstone's Avatar
Brimmstone
Clean your terminals then make sure they're tight. If this doesn't help take it down to your local parts store and have them do a full test on your starting and charging system. Most stores do this for free.
Super Econoline
25
Nov 25, 2012 11:21 PM
gjnicholas
Sep 20, 2011 07:17 PM
repower
Jul 16, 2011 06:32 AM
mantta
Aug 27, 2008 07:45 PM
