Sponsored by: Auxito
70 mph whistle
Old Sep 16, 2005 | 08:31 AM
murph1's Avatar
murph1
70 mph whistle
seems as though when i hit 70 mph i get a whistling noise coming from the passenger side of the truck..99 150...any one else get this also??
Old Sep 16, 2005 | 08:33 AM
Country4.2's Avatar
Country4.2
I get the same thing right at 70mph. I havent been able to figure out what it is. 2004 F150 Heritage 4.2L
Old Sep 16, 2005 | 03:08 PM
lancekilgore's Avatar
lancekilgore
check door seals,
Lance
Old Sep 16, 2005 | 07:38 PM
Racerguy's Avatar
Racerguy
A good way to tell if it's the door seals is to have someone ride along with you and pull the door in when the whistling is occuring. You can pull it by the window frame. If the noise changes you've found the problem and may be able to cure it by adjusting the door in a bit.
Old Sep 16, 2005 | 08:18 PM
preppypyro's Avatar
preppypyro
Maybe the window isnt fully rolled up to the top.
Old Sep 16, 2005 | 08:19 PM
bigdaddyII's Avatar
bigdaddyII
I used to have a horrible whistling comming from the passenger side at all speeds, even when I was stopped. It went away when I stopped riding my little brother around.
Old Sep 17, 2005 | 01:26 AM
Country4.2's Avatar
Country4.2
no it isnt coming from the door, it is coming from somewhere in the drivetrain, but I havent been able to figure out where.
Old Sep 18, 2005 | 11:19 PM
preppypyro's Avatar
preppypyro
Does it sound like a rear end type whine?
Old Sep 19, 2005 | 09:36 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Do you have side exit exhaust?
Old Sep 19, 2005 | 07:41 PM
murph1's Avatar
murph1
i don't have side exhaust..its coming from cowl under passenger feet area.. i have noticed that that the "whistle" is weaker just after changing out my air filter??????..but the intake air is on the other side of the truck..i kind of lean towards the fresh air vent...but don't have a clue how to find out for sure..
Old Sep 19, 2005 | 07:43 PM
murph1's Avatar
murph1
does fresh air come in near the wipers like on the older trucks?
Old Sep 20, 2005 | 10:10 AM
Country4.2's Avatar
Country4.2
I don't think air is making my whistle. It may be a rear end whine bc its not a high pitched whistle it has more of a whine sound to it. If it is the rear end, is this normal or should it be looked at??
HiZ
Jan 23, 2016 02:31 AM
90turbo1
May 12, 2015 10:40 PM
dr strangelove
2004 - 2008 F150
Feb 17, 2015 02:20 PM
LOFD
2009 - 2014 F150
Dec 31, 2010 09:17 AM
is300wrx
2004 - 2008 F150
17
Feb 20, 2007 09:39 AM
