in 4wd the a/c blows out the defroster vent??
On my 2004 F250 with 70,000 miles when i switch my truck in to 4wd with the a/c on it switches from blowing out the dash vents to the defroster vents. when i switch back to 2wd the air starts to blow back out the dash vents. Do you guys have any idea why this is or how to fix it? Thanks
If you're lucky it's a hub, otherwise you're chasing a vacuum leak all over the engine bay. There's a T joint that is common too. Basically you're not in 4wd if your defrost vents come on when you use the auto-selector. Mine is about 50/50, so normally I'll get out and switch the hubs manually. Remember, you need to move about 6" for the hubs to engage, so plan ahead.
1st you need to isolate the leak. Does the vacuum pump run cont? If so, disconnect vacuum line at the pump and put your finger over the pump outlet. If the pump stops the leak is in a line or device. If the pump continues to run or never did run then you have a bad pump. Before changing pump, make sure it is getting voltage. If not, check fuse. If the pump is good then keep expanding your search til the pump shuts down. Make sure that your hub vacuum lines are not leaking, check the vacuum line at the heater control valve and a vacuum connection behind the glove box door. These are common leak points. Hope this helps. Good luck.
Thanks you for any help...
Mine too, just noticed it yesterday.
Subscribed.
you can use a MityVac hand pump to pull a vac see if it holds vac
The last Guy that had this Issue was the Vac Control Silinoid
he could switch to 4X4 the hubs would lock IN but vents would go to defrost
If you switch into 4X4 and hubs dont lock you likely have a Leak in the Hub seal or Vac line to Hub
I had the same issue. Chech this tread out.
https://www.ford-trucks.com/forums/1104986-esof.html
Thanks to Mike Chan I got it fixed right the first time.
