Sponsored by: Kumho
Wheel Alignment
Old Sep 14, 2005 | 07:46 PM
wranglerastro's Avatar
wranglerastro
Wheel Alignment
I am looking for directions for doing my own front wheel alignment on my 86 F150 4x4 302 engine.
I learned the theory of wheel alignment and actually performed it on my daily runner 2001 Chevy Astro Van AWD.
This was only using a laser pointer and simple bubble level.
Not one out of 5 pro wheel alignment gave me good results. All kinds of excuses for why it is normal to have a slight pull to the right.
Now I can drive on level straight road without a correction for as long as 30 seconds rather than constant pull on the steering wheel to offset the pull to the right on the alignment.
However, I don't know which adjustments are for camber or caster. Which bolts have the cam bushing, etc.
If someone would know what goes where and how, please give me some directions. It would be appreciated. I did not consult any manual which I don't have.
Thanks.
Old Sep 14, 2005 | 07:55 PM
andym's Avatar
andym
First of all, the TTB is a pain in the rear end to align. Setting the toe isn't so bad, you just move the adjusting sleeves on the tie rod ends.
Setting the caster & camber is a whole nother story. You have to tear it down to the beam to get to the alignment shim. This means you have to remove the hub, caliper, rotor, spindle, and knuckle.
It's hard to describe how to set it, but it's one of Ford's worst designs ever. You cannot adjust camber seperately from caster. You touch one, the other moves. When you get it apart you'll see what I mean.
Old Sep 16, 2005 | 03:23 PM
Franklin2's Avatar
Franklin2
I thought the upper balljoint was mounted in an eccentric, and you turned this to adjust the camber. I keep hearing if you do a suspension lift, they have to put new cams in with more radical adjustment?
Old Sep 17, 2005 | 03:13 PM
wranglerastro
I was told by an alignment shop that my truck has cam bushings and not shims. But I am not sure where it is or what I am getting into. Before I mess things up I would like to find out what is involved to make camber / caster adjustments.
Thanks for anyone with some info.
Old Sep 17, 2005 | 08:28 PM
Franklin2's Avatar
Franklin2
Right in the middle of this picture they show the camber adjuster. The balljoint fits down inside it.
http://www.autozone.com/images/cds/g...3d800a49a4.gif
Here's a chart with the alignment specs. Notice there is no "preferred setting" for the caster. I bet it's not adjustable.
http://www.autozone.com/images/cds/g...3d800aa00f.gif
Old Sep 18, 2005 | 11:18 AM
wranglerastro
Thankyou Franklin2,
The diagram and chart are just the things I was hoping to get but didn't know to ask for.
The remaining question would be... does anyone know how the caster adjustment is made if it is possible?
Thanks guys.
Old Sep 18, 2005 | 11:23 AM
wranglerastro
By the way,
what does TTB stand for?
Where did Franklin2 get the diagram and chart? Would I be able to get to that site for other useful info?
Old Sep 18, 2005 | 02:06 PM
nick88f150's Avatar
nick88f150
Twin Traction Beam, looks like the site he got the pic off of is autozone
Old Sep 18, 2005 | 06:13 PM
wranglerastro
Thanks Nick88. I visited the site and got some interesting info.
I took a careful peek at my truck's front end.
What I saw seems to be this:
Upper ball joint sitting inside cam bushing that is keyed into the spindle.
So to change camber it would need to be swapped out to make any difference.
The caster seems to be built-in and not adjustable.
Would anyone be able to confirm the above?
In changing the cam bushing, does this mean that the upper ball joint has to come out first? Can I just hammer it out on the threaded end with the nut in place?
Thanks again, guys.
flkeysff
13
Sep 20, 2013 04:52 PM
AggieFord
6.7L Power Stroke Diesel
Jul 1, 2013 05:31 PM
iziris
1997 - 2003 F150
Feb 8, 2007 05:38 PM
TKAT79
Jun 11, 2006 09:18 PM
jdmclemore
2004 - 2008 F150
Sep 14, 2004 07:22 AM
