Brake Lines after adding Power Booster
Old Sep 14, 2005 | 01:20 PM
qman's Avatar
qman
I bought a power booster for my 72 and realized that if I slip it in behind the master cylinder the break lines will no longer mate up. How is this problem solved?
Old Sep 14, 2005 | 02:26 PM
Tech 1's Avatar
Tech 1
Smile
gman: You can approach this 2 ways. Go to the parts house and get 2 short pieces of brake line and 3 unions and 2 extra flare nuts and add them to your existing lines. The only problem you may face is you may have to flare the ends of your rear most line because I think the fitting is different than the lines you get at the parts house. I personally would add a section to the forward line and get a tubing bender and make a new line completely from the proportioning valve up to the master cylinder to replace the rear line. Another way is if your lines are coiled you may be able to stretch the coils out enough to make them work. It is my understanding that the coils are put in the lines to prevent vibration from breaking them but I don't think stretching the coils out some would affect it.
Old Sep 14, 2005 | 02:36 PM
4Cammer72's Avatar
4Cammer72
stretch the coils to make up the difference. there is plenty of line and you will still have coil left in the lines.
Old Sep 14, 2005 | 03:26 PM
flyflinger's Avatar
flyflinger
I just did this and just SSSSTTTTTRRREEEETTTCCCHHHEEEDDD the coils. Worked great so far!!!
Old Sep 14, 2005 | 04:03 PM
qman's Avatar
qman
Is it better to uncoil the coils or tighten the coils.
Old Sep 14, 2005 | 04:04 PM
flyflinger's Avatar
flyflinger
Grab the fittings and just give it a pull, so you are tightening the coils, but the stretch isn't that far. The coils have some give, just pull slowly.
Old Sep 14, 2005 | 09:10 PM
4Cammer72's Avatar
4Cammer72
yeah, like he said just grab it and pull it towards where you need it to go. dont try to unwind it or wind it tighter just pull it and it will give.
flyflinger's Avatar
flyflinger
Yeah, like 4cammer said.
Old Sep 15, 2005 | 10:28 AM
rebocardo's Avatar
rebocardo
When pulling up on the line, do not attempt to thread the fittings together until the connection stays lined up perfectly by itself and threads in easy. Otherwise you will strip the threads.
bluff3
Sep 24, 2013 08:24 PM
jonnykford
Bronco II
Jan 21, 2013 10:11 AM
rsdjcarter
Oct 4, 2008 02:49 PM
blakeusa
Jan 25, 2008 05:21 PM
Hausladen
May 17, 2002 12:11 PM
