Adding power brakes booster
Old Sep 24, 2013 | 06:56 PM
bluff3's Avatar
bluff3
I can I use the power brake booster from a 78 front disc brake on a 72 drum brakes? Is so were the best place to connect the vacuum line?
Old Sep 24, 2013 | 07:06 PM
HIO Silver's Avatar
HIO Silver
Yes. It'll also require a booster bracket and re-bending the brake lines. The ideal thing to do is to get the booster and bracket off a 70-72 to reduce the incertainties of compatibility.
A vacuum tee off the rear of the intake manifold - assuming it's a V8.
Old Sep 24, 2013 | 08:12 PM
Gembone's Avatar
Gembone
grab the pedal assembly as well
Old Sep 24, 2013 | 08:24 PM
MavSprint's Avatar
MavSprint
Good advice, incl the pedal support bracket. I was able to fit the '78, or so, power brake pedal into the '70 support using parts from each.
1974 f100
Sep 13, 2016 06:38 PM
mikeh74
Ford Truck Parts for Sale
Aug 12, 2015 09:26 AM
YooperUno
May 1, 2015 08:48 PM
olblue77
Nov 23, 2014 12:54 AM
FTE Ken
Jan 17, 2003 03:41 PM
