silicone brake fluid?????
Old Aug 6, 2002 | 05:51 PM
classyfish's Avatar
classyfish
Have any of you folks drained the old brake fluid out and replaced with silicone brake fluid????
Old Aug 6, 2002 | 07:38 PM
Franklin2's Avatar
Franklin2
I haven't, but I have heard alot of negative comments about it.
Old Aug 6, 2002 | 07:52 PM
FOMOGO's Avatar
FOMOGO
I have never flushed a system and replaced it with silicone brake fluid, but i have a 65' Mustang that had all new components, like a master cylinder, new lines, calipers and proportioning valve. I put silicone (Mortorcycle type) fluid about 4 years ago, and i have never had a problem. Some say it will draw moisture, but my car sits a majority of the time, through mild temp changes with no problems! I have never even had to bleed the system, and it still works as good as the first day i put it in. Good luck.... FOMOGO
Old Aug 6, 2002 | 11:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have heard it is OK with all new components but won't work with the old components that have had std brake fluid in them. You might try the guys in: Suspension, Tires and Wheels forum. There is a newer spec DOT-4 fluid that has a higher boiling point than DOT-3 fluid and is compatible with the DOT-3 fluid.
Old Aug 7, 2002 | 10:58 AM
beartracks's Avatar
beartracks
I've been using silicon fluid for years. I started using it in custom motorcycles because it wont eat the paint if you spill it. It is non hydroscopic (doesn't attract water) and therefore doesn't corode the internals of your brake system like regular fluid. I've never had any problems with it.
however: do not use it in ABS systems as it can foam from repeated pulsations. I also would not use it for racing, towing or if I lived way up in the hills where you might get it to foam from continuous applications of the pedal. It has never had this problem in my truck over the last 15 years.
Old Aug 7, 2002 | 12:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Old Aug 8, 2002 | 02:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
I think the silicone fluid has a higher boiling point than either DOT 3 or 4 fluid and it does not eat the paint:-)
Macs1964F100
Jan 5, 2014 08:12 PM
Outlaw56
Oct 11, 2013 11:38 AM
40willys
Jan 7, 2009 08:12 AM
rjhuey
Aftermarket Products
Jul 24, 2002 01:08 PM
leonharu
Jun 26, 2002 10:03 PM
