Sponsored by: Real Truck
DRW Brake Rotor Question
Old Jan 6, 2009 | 06:28 PM
40willys's Avatar
40willys
Putting new rotors on my 2002 Ford Dually & was wondering if anyone knows what the ratchet/nut torque rating is & is the factory brake fluid DOT 3-4 or is it the silicone based DOT 5?
Old Jan 6, 2009 | 08:46 PM
FireMe's Avatar
FireMe
Lug nut torque is 165 lb/ft.
Fluid is DOT 3.
Old Jan 6, 2009 | 08:57 PM
highland61's Avatar
highland61
if your talking axle nut it is something like 60 ft lbs and then back off 7 clicks for new bearings and 5 for used bearings.
Old Jan 6, 2009 | 09:14 PM
FireMe's Avatar
FireMe
Good call. I wasn't sure which one he was talking about when I read it.
So, to cover all the bases:
Rotor to hub bolts: 66-68 lb/ft.
Hub nut:
Torque to 70 lb/ft.
Back off 90 degrees.
Retorque to 18 lb/ft.
Install dial indicator and verify hub has zero end play.
Check that rotating torque of hub does not exceed 20 lb-in.
Old Jan 7, 2009 | 08:12 AM
40willys's Avatar
40willys
thanks guys, this site is awsome
senix
Crossovers
Oct 24, 2014 02:41 PM
ukmat71
Mar 11, 2010 04:40 PM
supercab78
May 21, 2007 06:58 PM
rangedog
Oil & Lubrication
23
Mar 1, 2004 11:51 AM
