i need some welder recomendations
im kinda new to the fabrication hobby but i really am interested in it. i am looking at buying a welder for my garage. i plan on just doing basic welding roll cages bumpers some frame work and chassis fab. any ideas on a good mig or tig or mig/tig welders? i would like tokeep the price kinda low, hopefully have a good duty cycle and be able to weld anything for body panels to 1/4 inch plate steel or more. any advice on buying a welder would be greatly appriciated.
adam conter
sgt u.s. army
adam conter
sgt u.s. army
First, I would recommend doing a search on this forum, as this has been discussed before. Sounds like you would probably want a mig, around 200 amp if you want to weld 1/4". Stick welders are fine for big stuff, but a mig is great for sheet metal work, once you learn the tricks. A tig is also great for smaller stuff (the best, IMHO) but they are expensive and harder to use. I find mig easiest. I had an HTP 200, and it did everything I wanted, from body work to over 1/4". Now they are almost the same price as Miller or Lincoln, and I would recommend one of those two, simply because any welding supply place will have parts and consumables. I've never tried flux cored wire, but I don't imagine it is as clean and easy as using shielding gas. I'll be buying a Miller 210 within a year, I hope.
Welding "roll cages, bumpers and frames" is not your "basic" welding, you need to go to welding classes and learn the proper techniques to have structurally
strong sound welds. With a quality Tig and Mig machine that has power, not a 120 volt Mig you will have $6,000 invested, I ***** you not. Good welding.
.....=o&o>.....
.....=o&o>.....
You need lots of practice before you build a roll cage. This is something that your life can depend on in a bad situation.
Having said that, you need TIG for the highest strength welds. Stick is almost as strong, and MIG is way back in third.
thanks for the info. i do have experience with mig and stick. welding on tank hulls(steel) personel carriers(aluminum(pain in the ***)) and various crap for the army lol. i have enough training to feel confident in my abilities to knock out a roll cage and bumpers. basically i am looking for a good quality welding machine something better than the crap i use here in the army. thanks for the input though and keep it coming!!!
The cheapest mig I have found with a 200amp rating is a Clark, found it at a local hardware store, the cost was $1000. This cost does not include a sheilding gas tank, which cost around $300 if you want to title the tank. Another option is to rent a tank from a local dealer, this costs me $7.00 a month not counting the gas.
Not sure about the reliability of the Clark machine but the price is very inviting when a good Miller will cost about $2500.
My preference is Miller, I have a Syncrowave 250 in my garage. I also have a 115V wire feed welder with gas capabilities. I use the TIG or Stick(on the Syncro)to weld heavier materials and the wire for small stuff like body panels and exhaust.
Pass on the clark! You can get a brand new Miller 210 for under $1300 and that's a hell of a lot nicer machine. To be totaly honest a miller 175 would be perfectly fine for what you're doing and you can get those under $700. The duty cycle is lower then the 210 but for the work you're describing you'll never have a problem.
cosmaar1
Oct 17, 2014 11:41 AM
