Sponsored by: Real Truck
Pitman Arm nut problem
Old Sep 12, 2005 | 12:47 PM
Boondog's Avatar
Boondog
I am having a problem with my SD. The nut is loose and the lock washer spins. The nut appears tight but I would like to know what size the nut actually is. The truck is a F-350 with 6" of lift. I know this puts extra leverage on the shaft and obviously the arm should not loose. I am gonna buy some 3/4" drive sockets to tighten this nut but what size is it?
Old Sep 12, 2005 | 01:12 PM
EnviroCon's Avatar
EnviroCon
I believe the socket I used was a 1 5/16". I'm not at home at the moment, but I'm almost sure that is what it was.
ON EDIT: I believe you can also use a 32mm, but I kind of remember it being a tight fit.
Old Sep 12, 2005 | 01:15 PM
rwilimo's Avatar
rwilimo
I agree 1 5/16"
Old Sep 12, 2005 | 02:46 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 13, 2005 | 01:34 PM
EPDP99's Avatar
EPDP99
Factory tourqe on my 05 is like 350 ft/lbs. Be sure to check the tourqe on it. Also sounds like a good time to torque everything else that was added to suspension...
Old Sep 13, 2005 | 02:23 PM
Boondog's Avatar
Boondog
Update
I just got a 1 5/16" socket and it appears to be a loose fit. I tried a breaker bar with a jack handle and it slipped. I don't want to round the corners off so I may have to try the 32mm mentioned earlier. I am trying to avoid replacing the box as I imagine it must be expensive and probably a pain to replace. I will probably go over the rest of the truck as well for tourque specs. The lift was installed by a seemingly intelligent guy but I am starting to question that.
Old Sep 13, 2005 | 02:32 PM
rwilimo's Avatar
rwilimo
Did you get a 6 point or 12 point socket? A 6 point would be a lot better. If the washer is that loose and nut is that tight I would be trying to get the nut off to see what's wrong, either you ran out or threads which would indicate some kind of pitman arm problem or the nut is stripped which needs to be repaired. I can not stress to you enough how important it is to fix this the right way.
Old Sep 13, 2005 | 02:52 PM
Boondog's Avatar
Boondog
Belive me, I realize how important this nut is. I would not want to loose steering in a 7000lb vehicle. It is currently not being driven til it is fixed as it is scary to drive with that much slop in it anyways. I believe it is a 12 point socket. I didn't even think about it until something was said. It was all the parts store had anyways so it was worth a shot.
Old Sep 13, 2005 | 03:37 PM
Jokenring's Avatar
Jokenring
Everything on these trucks is metric. I wouldn't want to use standard sockets unless you like rounded nuts.
jacecil082
Feb 21, 2017 02:47 PM
hwybee22
Oct 26, 2016 09:15 PM
vegas5701
1997 - 2003 F150
Mar 7, 2016 07:35 PM
65oldie
Oct 26, 2015 09:41 PM
MY FYN 79
Oct 18, 2015 04:13 PM
