Maintenance Questions
Old Sep 11, 2005 | 11:33 AM
04edge4.0's Avatar
04edge4.0
1) Where is the fuel filter on a '04 Ranger 4.0L?
2) What is the recommended mileage to change rear diff. limited slip oil?
What type of rear diff. oil should be used if the ford oil is not used with the additive for limited slip?
Old Sep 11, 2005 | 07:32 PM
Ken00's Avatar
Ken00
The fuel filter should be under the passengers compartment on the drivers side frame rail.
The rear should be good for 60-70k miles unless you get it under water. Non FX-II takes 80w-90 gear oil and 4oz of friction modifier, if you get it at the parts store just make sure it meets the Ford specificaton in your owners manual.
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
brian931
Apr 8, 2009 07:16 AM
Hunters
Oil & Lubrication
Feb 4, 2009 10:16 AM
Grogtronics
Oil & Lubrication
Sep 9, 2008 08:14 PM
Yellow01Edge
22
Jun 28, 2005 11:09 AM
