Do i have a limited slip diff
Old Jun 9, 2005 | 04:09 PM
Yellow01Edge's Avatar
Yellow01Edge
Question Do i have a limited slip diff
I have a 01 Ranger Edge.. .and i was curious if i had a limited slip diff?????? its the 4.0 4wd 4dr. thanx for helpin a newbie.....
Old Jun 9, 2005 | 07:49 PM
el conquistador's Avatar
el conquistador
my guess would be yes but check the sticker on the driver side doorjam for the axle code. it will be at the bottom of the sticker.
Axle Codes
The following lists the gear ratios on axles.
· 86 — 3.73 non-limited slip, 2.5L, 3.0L engines, 4x2.
· 87 — 4.10 non-limited slip, 2.5L, 4x2.
· 89 — 4.56 non-limited slip, 2.5L, 3.0L engines, 4x2.
· F6 — 3.73 limited slip, 2.5L, 3.0L engines, 4x2.
· F7 — 4.10 limited slip, 2.5L, 3.0L engines, 4x2.
· 95 — 3.55 non-limited slip, 4.0L engine, 4x2.
· R5 — 3.55 limited slip, 4.0L engine, 4x2.
· 86 — 3.73 non-limited slip, 3.0L engine, 4x4.
· 87 — 4.10 non-limited slip, 3.0L engine, 4x4.
· F6 — 3.73 limited slip, 3.0L engine, 4x4.
· F7 — 4.10 limited slip, 3.0L engine, 4x4.
· 97 — 4.10 non-limited slip, 3.0L engine, 4x4.
· R7 — 4.10 limited slip, 3.0L engine, 4x4.
· 96 — 3.73 non-limited slip, 4.0L engine, 4x4.
· 97 — 4.10 non-limited slip, 4.0L engine, 4x4.
· R6 — 3.73 limited slip, 4.0L engine, 4x4.
· R7 — 4.10 limited slip, 4.0L engine, 4x4.
Old Jun 10, 2005 | 05:15 AM
99xltsuper4x4's Avatar
99xltsuper4x4
Smile door codes
I have a 99 3.0 and the door sticker says axle code 97. Does mean that 97 is for both 3.0 and 4.0 4.10 ratio non limited slip?
Old Jun 10, 2005 | 06:22 AM
Dan Robertson's Avatar
Dan Robertson
Another way to tell is to jack up both rear wheels, put the truck in neutral and manually turn one of the rear wheels while watching the other side. If the other wheel turns backwards, you do not have limited slip. If it turns the same way, you do.
Old Jun 10, 2005 | 08:32 AM
el conquistador
generally if there is a letter and a number in the code, it is limited slip, if there are 2 numbers it is non limited slip.
Old Jun 10, 2005 | 08:25 PM
Old Speed's Avatar
Old Speed
on my 02 ranger if you look at the reat axle tag it will have a L on it for Limited slip
Old Jun 14, 2005 | 09:24 AM
Yellow01Edge
Talking
okay i just looked today and it is and r7 so here is another newbie question.... whats the difference between the 3.73 and the 4.10.... Whcih is better, Wose, cons ,pros?? all the good stuff thax a lot for everyone that is helping me.. also does everyone 01-04 ranger have a 93 mph limiter on it???
Old Jun 14, 2005 | 01:28 PM
Old Speed's Avatar
Old Speed
yes all rangers have a speed limiter at 93mph from what i know on the 01-05 well the gasmilage is wourse on the 4:10's because it is a lower geer and gives you more toque and the lower the geer # the higher the geer is and will give you more top end(please correct me if im wrong) here is a post from franken truck on a nother thread showing the diff in ring and pinon size and tire size. might be helpful in understanding
Originally Posted by Franken-Truck
The 300 isn't a high reving motor. I would avoid 4.56 with a 36" tire. For the best over all performamce (street & offroad) go with the 4.10's. 35" tires should fit fine. Really depends on what your doing with your truck though. If your truck spends most of its time off road (or you have OD), go with higher ratio gears. If you spend most of your time on the road like me, you'll like being able to get some where without the engine screaming with slightly lower ratio gears. I usually cruise around 65-70 mph, so I'm geared accordingly. Just my humble opinion
4.56/36"
-70mph=3000rpm
-59mph=2500rpm
4.10/36"
-78mph=3000rpm
-65mph=2500rpm
4.56/38"
-74mph=3000rpm
-62mph=2500rpm
4.10/38"
-83mph=3000rpm
-69mph=2500rpm
Old Jun 22, 2005 | 01:38 PM
0RangerEdge2's Avatar
0RangerEdge2
I'm confused. My truck is a 02 Edge with the 3.0 and 4x2. It says I have axle 97 so that is a 4.10 non limited slip but 4x4 according to el conquistador. Also with that combonation I would think I could spin the tires on dry pavement and I barely get a squawk.
Old Jun 22, 2005 | 02:54 PM
Dave257's Avatar
Dave257
https://www.ford-trucks.com/lc/lc.ph...ationCodes.doc
Here is a link for the vin decoder; check the engine code and see what it has for the rear end code
Dave
Old Jun 22, 2005 | 07:13 PM
0RangerEdge2
I need a vin decoder for the 2002 model year, because the 2000 you posted a link to gives me incorrect information such as the axle code and the VIN numbers don't match up
Old Jun 22, 2005 | 07:25 PM
Dave257's Avatar
Dave257
Here is one for later Fords
https://www.fleet.ford.com/maintenan...ls/default.asp
This link dosen't work??? but it is the correct address..
Dave
Old Jun 22, 2005 | 07:47 PM
Rockledge's Avatar
Rockledge
This is out of the 2002 Ford Manual:
Ranger
86 — 3.73 non-limited slip.
87 — 4.10 non-limited slip.
89 — 4.56 non-limited slip.
F6 — 3.73 limited slip.
95 — 3.55 non-limited slip.
R5 — 3.55 limited slip.
96 — 3.73 non-limited slip.
97 — 4.10 non-limited slip.
R6 — 3.73 limited slip.
R7 — 4.10 limited slip.
KA — Electric vehicle (no ratio).
The axle code is on the door sticker.
Old Jun 25, 2005 | 04:32 AM
99xltsuper4x4
Thanks Rockledge, that clears it up for me.
Old Jun 25, 2005 | 04:27 PM
0RangerEdge2
Well I am still confused because I can lay a burnout with BOTHtires. Maybe the dealer changed it because the dealer owned it until I just got it
