My wife got the driver's side window on our 2002 Excursion stuck in the down position. When I press the up botton, I don't get any clicks, gratting sounds or anything. All the other windows work fine. Any idea what it is, or how I can fix it?
...Welcome jfoil, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Welcome to FTE!
If the motors not working in the up position, I would suspect the switch. Pop off the power window/lock panel and check for loose connection or bad switch.
After my personal experience with Ford power window motors (and reading many other threads), I'd suspect a bad window motor. If checking your switch panel doesn't get you anywhere, connect a straight 12 volts from your battery to the wires on your window motor, and see if you get anywhere.
If you want to try out a window motor, I have a brand new remanufactured motor that I bought (and installed, then uninstalled) that I didn't end up needing, as it ended up being my switch that was the problem. I paid $46.99 for it plus a $30 core charge. I'd be willing to give you a great deal on the motor if you'll send me your old one back so I can get my $30 back for the core charge. PM me if interested and we can work out a deal.
